Cutting down a 60" rear blade to 54"
   / Cutting down a 60" rear blade to 54" #1
ericher69
Ontario Canada
2008 Kubota b2920
Considering cutting down my 60" rear blade (mostly used for snow) down to 54"
Reason; front blower is 51" and I get lots of spoil now
Will still need some blower "wings" but will only need 2-3 inches per side compared to 5-6 inches per side now
Tractor is kubota b2920 (1500lbs dry weight) not counting blower, undercarriage, rear blade and sims cab
I have zero issue with pto horses lacking!
Let me know what u think
Thx
   / Cutting down a 60" rear blade to 54" #2
Not sure what you are trying to accomplish by cutting it down. for snow you would want a rear blade a little bigger than if you were just using it for dirt.
A smaller blade will cut better, but require more passes.
I cut a 7.5' snow plow down to 6.5' because I feel it's the right fit for my machine. big enough, but not so big that I can't push it.
I also cut a 5 foot bucket to 4 foot just for a sidewalk that could get buried by street snow plow.
So I'm all for cutting down if it will suit your needs.
JB.
   / Cutting down a 60" rear blade to 54" #3
Do you ever angle the rear blade? if you angle a 60 in blade it will be less than 54 inches pretty quick
Jb
My blower is currently 9" narrower than rear blade...
Spoil ++ when doing first pass and edge passes
Thought about wings but 5.5-6 inches per side is a bit much
I thought about angling but I need straight to remove snow close to buildings etc.
Unless I go hydraulic angling?
   / Cutting down a 60" rear blade to 54" #5
Jb
Can't you just get off the tractor and manually angle the blade perpendicular (straight) to the tractor...or even a bit (15 degrees or so) away from the buildings? It really isn't that mch work, is it?
Personally, I think you'd regret cutting that blade down...
Royjackson;
I'm not lazy but...
Getting in and out of a cab at least twice per drive at 50+ residential drives per snow fall adds up to major time wasted and $$
   / Cutting down a 60" rear blade to 54" #7
If you are doing this for money, then you need to keep the full width blade and make it so that it has hydraulic angling. :thumbsup:
   / Cutting down a 60" rear blade to 54" #9
Royjackson;
I'm not lazy but...
Yes, it would...I thought you were doing this for your home only.
You'd be better off with a front blade (for most snows...6-8 inches of less), I think.
   / Cutting down a 60" rear blade to 54" #10
If you have a blower, why the need for a blade at all.??
Torro Groundmaster 3280D Riding Mower (A59814)
Torro Groundmaster...
1999 Case IH 4300 Field Cultivator (A59814)
1999 Case IH 4300...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
Bobcat T590 (A53317)
