Is a Subsoiler worth it?
   / Is a Subsoiler worth it? #1
Baranx4
Gold Member
Northeastern, Pa.
I was thinking about a subsoiler for my fields. I have a few areas that stay wet longer and really don't drain well. I was thinking of drain tile but think that would be an overkill. Anyone with any subsoiler experience. I know whatever I purchase will be shear pin protected.
   / Is a Subsoiler worth it? #2
I built my subsoiler from a grader blade, works great opening up the ground and at flipping boulders out and cutting tree small roots away from my septic bed.
Click on Utube for farms running subsoilers in their fields, cheap way to see them in action .
   / Is a Subsoiler worth it? #3
here is how it turned out doesn't tear the ground up too awful bad.
   / Is a Subsoiler worth it? #4
this pic just shows how deep it can go, it is sharpen to slice better as well.
   / Is a Subsoiler worth it? #5
Yes, a subsoiler will definately allow clay soil to drain more completely and also increase crop yields because the roots have less of a struggle. The clay soil takes a while to fall back in on itself so the drain aspect works.
A gravel type soil is hard to compact and also subsoiling does little good because it is fragile and seals itself over quickly.
   / Is a Subsoiler worth it? #6
I did quite a bit of research on the internet with regards to the effectivemness of subsoiling and there is no definative answer. There are just as many situations where subsoiling decreases the productivity of land as there are where it helps.
I went ahead and bought a Fred Cain subsoiler however haven't had it long enough to determine if it solves the soil challenges I have. My problem clay hard pan that prevents the moisture from properly soaking in. The ground stays wet way too long in the spring. I guess drainage is what I too am hoping to solve.
   / Is a Subsoiler worth it? #7
I dont think a subsoiler is going to help you in the drainage problem. It may allow the surface water to penetrate deeper into the soil but beware that breaking the clay hardpan also will allow you to bog deeper into the ground if you venture into with your tractor. We used them on the farm to loosen up the middle where the tractors tires ran on rowcrop farming. Other than that, they didnt seem to be of much value in increasing root penetration. Most of your usable nutrients are in the top 6 inches of soil for the feeder roots. Tap roots dont seem to have any problem with penetration into tight soils.
A good drainage ditch sounds like what you need to cure your problem. We just finished up with some dozer work laying some rock for erosion prevention, spreading out some dirt piles and while we had the dozer, we had several more ditches opened to remove some standing wet spots from weeping springs. Our land seems to have them at the bottom of every hill. They dont run but just weep and keep large areas wet. We put in some swales to drain them to local creeks nearby to hopefully eliminate the problem. Amazingly the dozer stood up on the mud much better than our tractors which tended to sink deeply into the quagmire. Should have got a photo of my Yanmar setting with the floorboards below ground level a few years ago in one such area. Luckily we had a backhoe nearby to pull me out.
   / Is a Subsoiler worth it? #8
A subsoiler won't promote drainage so much as allow soil at depth retain moisture better. The advantage will be rain will soak into the ground more readily though excess still needs to run off. So while you may see less of a standing water problem, it won't be a cure. proper sloping of the ground for drainage is still the key.
Our issue is also the hardpan. When we built our home it took digging in several areas to find an area that would perk due to the hardpan. I'm interested in less lying water. I'm not looking for it to be perfect just less standing water.
   / Is a Subsoiler worth it? #10
In the clay of central Ohio, a subsoiler at 12" breaks the hardpan. Any deeper tends to invert the soil and science now suggests not to go too deep. On drainage, I subsoiled my wet areas at 12"-and 14" and my wet problem was solved. There is no more standing water and we are around 15" above normal rainfall for the year with an especially wet spring.
For reference, the Deere 22B single shank subsoiler (look it up) has a "mole ball" attachment that looks like a long cast iron egg and is attached to the foot of the subsoiler with a chain. It is said to make drain channels in soil to allow more water to vent. I don't know about that but I did see that attachment on the ones I have seen for sale.
This is a pretty subjective opinion thing here so ask a couple local people as well.
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
500BBL WHEELED...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
