JD 4200 steering wheel spins freely
   / JD 4200 steering wheel spins freely
I really hope it is something simple like that. The wheel did not feel loose or have play, but I did not check the nut for tightness. Since the wheel firmed up when the tractor was shut down I assumed that it was mechanically intact. I am going to get down there ASAP (hopefully tomorrow) and will get back with more details.
Thanks all.......
   / JD 4200 steering wheel spins freely #22
My 4310 did just that......after I dropped it off the edge of the drive onto a stone retaining wall in a blizzard. The stone wall BROKE the steering cylinder rod. Have you ever tried to get a tractor off a stone wall in a blizzard with no steering? It is as much fun as it sounds. The cylinder was $410. Hope yours ends better.
Mfreund,
Was the rod visibly broken? mine appears intact unless it broken internally.
   / JD 4200 steering wheel spins freely #24
JD4Life, do you have an up-date for us?
   / JD 4200 steering wheel spins freely #25
I would agree the hyd rod in the steering cyl is either broken internally, nut came off of the hyd rod or piston seal blown.....:thumbsup:
Alright, I had to travel for business to Charlotte NC. I will be back with the tractor Friday AM. I am convinced that the cylinder has failed internally and have purchased a new one (since no rebuild kit exists) $410 ouch..... I will have an update and hopefully a running tractor Friday afternoon. Thanks all for the help and interest.
   / JD 4200 steering wheel spins freely #27
JD4life,
I'd appreciate it if you could post a pic of the (new or old) cylinder for reference (whereas a kit is not avail), It may help someone in the future
   / JD 4200 steering wheel spins freely #28
jdparts shows two different cylinders for the 4200.
One (15B) looks to be repairable and the other (15A) not.
Ok so it was the hydraulic cylinder. When I unbolted it from the steering knuckle and disconnected the hydraulic lines, the shaft slid right out. It appears that the piston stripped the threads right off. New one bolted in and it is working great. Pictures to come.
   / JD 4200 steering wheel spins freely #30
This is good news. Not a cheap fix, but it could've been a lot worst. :thumbsup:
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2019 Dorsey DF40 40ft. 40 Ton T/A Drop Deck Flatbed Trailer (A60460)
2019 Dorsey DF40...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
John Deere 7000 8R Planter (A59814)
John Deere 7000 8R...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
