I tipped my Kubota!
   / I tipped my Kubota! #61
I do not see where that is a problem. The further out the weight, the more effective it is. My 7' cutter is a more effective counterbalance than my 7' box blade even though I think the BB is the same weight or a little heavier. The only issue I see is that I have to watch more carefully where the rear end is if I am maneuvering in tight quarters.
I'm curious as to why you see an extended weight as a problem.
Ken
Ever have that rotary cutter sway on you during transport? Even with the sway links, you won't get all the sway out.
On a level area, you'll still feel it...especially if you turn too fast.
Now, think about that sway when the cutter is mounted to a 2200 lb tractor...operating across a slope. Wouldn't be too difficult getting into a "tail wagging the dog" situation.
   / I tipped my Kubota! #62
No, I haven't had it sway on me. I have stabilizer bars and it doesn't move any noticeable distance sideways. But I can definitely understand what you are talking about if you have side to side sway.
Ken
   / I tipped my Kubota! #63
Ken
About the best I could ever get, once adjusting the sway links (turnbuckles) tight...I'd still see 3" or so sway at the cutter's tailwheel.
I never used my cutter for ballast (even though it's the heaviest implement I own). As you wrote..you really got to watch it in close quarters due to it's length.
I do transport it across a sloped lawn to get to a field next door (I used to maintain the whole field...about 5 acres) and I could really feel the cutter's weight everytime it shifted. I wasn't going across the slope...but even downslope was somewhat uneven.
   / I tipped my Kubota! #64
If you bought KTAC Insurance, why would you spend your time guessing on what might be wrong and potentially damage your tractor even more? In my opinion, the only advice you need is to call your dealer and have them come pick it up and check it out for you. It will cost you $250 for your deductible (that's it). We will pay for the repair and transportation to and from the dealership. In most cases, the equipment would have already been inspected, repaired, and delivered back to you by now. Just saying... you have insurance for a reason so why not use it?
(Why am I trying to get you to use insurance? Because I hope you will keep buying Kubota after you see how we take care of our customers. Everyone WINS!)
PS - When I refer to "you", I mean anyone that has bought our insurance. :thumbsup:
   / I tipped my Kubota! #65
(Pardon the thread creep here, please.)
Ktac, I just bought a used 2008 B2620 with 112 hours from a private party . Can I get insurance on it? And how much? You can PM me if you like. Thanks.
   / I tipped my Kubota! #66
We definitely can but I will need the value you want to insure. Just go on-line (ktacinsuranceagency.com) or call us at 800-348-5802 for a quote. You can pay via credit card and have insurance in place within 10 minutes.
All is good! :) I let the engine sit for 2 weeks and it started up just fine today. I continued my loader work and all went well. After moving to a more flat area, I could see that the hydraulic fluid level is fine too.
I chose to not pull the plugs for two reasons. One, the gas tank assembly would need to be removed as it sits on top of the engine. Two, a Kubota mechanic said I "should" be fine. Very rairly does oil get through on these new engines and if it does, it "should" drain back over time.
Thanks again for all the help.
   / I tipped my Kubota! #68
Glad it turned out well for you. I've had a couple scares with my tractor. Fortunately for me everything turned out ok for me too. I did learn something from this thread. I had noticed my tractor is more tippy side-to-side when a heavy load is in the FEL but I didn't know why. Thanks for posting about your episode. I'm sure it has helped others too.
Obed
   / I tipped my Kubota! #69
The waiting would have killed me. I'm not an impatient person but waiting and trying to guess how long to wait wondering if any oil would drain back or not would have drove me nuts. Glad it worked out.
   / I tipped my Kubota! #70
Glad you are going again..all in all you came out pretty well, could have been worse!
James K0UA
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
Jaw Crusher (A59228)
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
