Do you add any kind of Additive to fuel?
   / Do you add any kind of Additive to fuel? #11
There's a number of quality fuel additives on the market. I'm not necessarily a "brand" snob at all... I am familiar with what has worked for me over the year's and what is readily available (on the road - at home). So, I don't have to "hunt" for fuel conditioner when I need it - I use Power Service.
AKfish
I like that- don't need to hunt for things and use what works for you.
I have used white PS too, this was before TSC opened near me and now I have other brands available to me like howse. Why switch if PS works just fine. I have NOT come across any negative issues using it no matter what the hearsay is.
   / Do you add any kind of Additive to fuel? #12
PS (White and Emergency Red) is standard issue to all our fleet drivers in the winter. Every truck has at least 2 bottles in the cab side compartment.
It works, it stinks and it's inexpensive.
   / Do you add any kind of Additive to fuel? #13
Just curious if anyone adds anything to their diesel fuel for the winter months?
I do, it is called "Diesel fuel".
I add it when the gauge approaches "E".
On the small tractor I add about 5 gallons, which is a convenient can size.
The bigger ones usually get a transfusion from the truck, unclear how many gallons at a time, maybe 15 or 20.
Around here (North East USA) it can be unwise to leave a diesel with summer blend in it much past December 1st.
   / Do you add any kind of Additive to fuel? #14
I don't have to,but I add Power Service also.
I think it boosts the Cetane a bit.
I get my diesel where I get my gas (Sunoco) and I've never had a problem:thumbsup:
Greg
   / Do you add any kind of Additive to fuel? #15
Havent used anything for 20 years
what benefit would there be
would the tractor feel better
   / Do you add any kind of Additive to fuel? #16
I use marine grade stabil in all my gasoline powered engines. You need to today, but you did not before they put up to 10% ethanol in the gas. Ethanol is what they call hydroscopic, so it attracts water. I'm pretty good about putting fresh gas in my stuff when I change oil in the fall and put it away, but I've had problems the past two years that I attribute to the ethanol in the gasoline. I had a seeded last year with a B+S 13 HP engine that would not run this spring, even though I drained the gas. I think the little that was left in it attracted water and it formed little jelly balls in the carb, along with some rust, something I have never seen before.
Wayne
   / Do you add any kind of Additive to fuel? #17
nope...ive had diesels for about 20 years, and while i do use a winter blend in the cold climates, i never add any fuel additives. Never had any issues.
   / Do you add any kind of Additive to fuel? #18
Some of us run #2 fuel oil, so there is no anti-gel additive making an additive a must in the winter.
   / Do you add any kind of Additive to fuel? #19
Winter blend is just that. Your oil company is pre-adding anti-gel, keroscene or some other additive.
ULSD is like ethanol. Green mandated crap.
   / Do you add any kind of Additive to fuel? #20
I use winter bottle PS in the winter and Silver bottle PS in the summer.
I have 3 diesels, a Dodge Cummins, a VW Jetta TDI(CR), and my tractor.
There has been alot of discussion on TDIClub about fuel lubricity(or lack thereof) contributing to a number of High pressure fuel pump failures in the TDIs. I really don't want to spend $8-10K replacing the WHOLE fuel system in the TDI if it is related to fuel lubricity so I run the PS. Part of the problem (at least with the TDI) is that the maker of the fuel pump(Bosch) spec'ed the system to run with 460 max wear scar test fuel and most if not all fuel sold in the US is allowed to have a 520 wear scar.
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
207277 (A52708)
207277 (A52708)
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
404 (A52706)
404 (A52706)
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
Toro (A56857)
Toro (A56857)
