1920 Cranks - Won't Fire
   / 1920 Cranks - Won't Fire #11
good point.. that make sa big difference. might be something like rack closed// etc..
No she ran fine, just wanted to do some routine maintenance. It is a gear model so I will pull it at some point if necessary, but I want to re-check my bleed process and make sure I cover all points. I'll take a closer look at the filter tomorrow now that I'm home. I'll post a picture as well so you can see what I see. Again, appreciate all the help.
   / 1920 Cranks - Won't Fire #13
Todd, don't really have any advice that hasn't been suggested, but if you need photos or anything else from my 1920 just let me know. Bill C
   / 1920 Cranks - Won't Fire #14
pulling is way easier on the starter...
   / 1920 Cranks - Won't Fire #15
It takes two to pull:D:D, being short handed might cause an issue. I have to always do things by my only self.
JC,
   / 1920 Cranks - Won't Fire #16
i find myself getting stuck like that often. needing a 2nd person. when none can be found.
   / 1920 Cranks - Won't Fire #17
Clamps, tape, coat hangers, and a good magnet have helped me make a third hand at times.:laughing:
I've seen more than one truck crawl across a field with no driver and a guy in the back busting hay bales for the herd. Not sure this would be advisable to pull a tractor though.:shocked:
   / 1920 Cranks - Won't Fire #18
Since you pull it in gear, how are you gonna stop it if it fires off and starts running up your backside?:eek: Pullin' is the easy part.:D
   / 1920 Cranks - Won't Fire #19
That's what i was thinkin' Jim. Would make a great U-tube video though. :laughing:
   / 1920 Cranks - Won't Fire #20
btdt.. old flatbed with split gears and a granny. 2 bunji cords and a long field and low idle.. :) hop in at the end of the row and swing 'er around..
2015 Peterbilt 320 Heil 28Yd Side Loader Garbage Truck (A55973)
2015 Peterbilt 320...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2013 Chevrolet Silverado 4x4 Service Truck, VIN # 1GC2KZCGXDZ156404 (A57453)
2013 Chevrolet...
2017 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52709)
2017 CATERPILLAR...
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
CATTLE SHOOT (A52708)
