1920 Cranks - Won't Fire
   / 1920 Cranks - Won't Fire #11
good point.. that make sa big difference. might be something like rack closed// etc..
No she ran fine, just wanted to do some routine maintenance. It is a gear model so I will pull it at some point if necessary, but I want to re-check my bleed process and make sure I cover all points. I'll take a closer look at the filter tomorrow now that I'm home. I'll post a picture as well so you can see what I see. Again, appreciate all the help.
   / 1920 Cranks - Won't Fire #13
Todd, don't really have any advice that hasn't been suggested, but if you need photos or anything else from my 1920 just let me know. Bill C
   / 1920 Cranks - Won't Fire #14
pulling is way easier on the starter...
   / 1920 Cranks - Won't Fire #15
It takes two to pull:D:D, being short handed might cause an issue. I have to always do things by my only self.
JC,
   / 1920 Cranks - Won't Fire #16
i find myself getting stuck like that often. needing a 2nd person. when none can be found.
   / 1920 Cranks - Won't Fire #17
Clamps, tape, coat hangers, and a good magnet have helped me make a third hand at times.:laughing:
I've seen more than one truck crawl across a field with no driver and a guy in the back busting hay bales for the herd. Not sure this would be advisable to pull a tractor though.:shocked:
   / 1920 Cranks - Won't Fire #18
Since you pull it in gear, how are you gonna stop it if it fires off and starts running up your backside?:eek: Pullin' is the easy part.:D
   / 1920 Cranks - Won't Fire #19
That's what i was thinkin' Jim. Would make a great U-tube video though. :laughing:
   / 1920 Cranks - Won't Fire #20
btdt.. old flatbed with split gears and a granny. 2 bunji cords and a long field and low idle.. :) hop in at the end of the row and swing 'er around..
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
10"x161/2' ROUND STOCK (A58374)
10"x161/2' ROUND...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2011 Ford E-350 Cargo Van (A56858)
2011 Ford E-350...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
PJ 102" X 24' GOOSENECK TRAILER (A52708)
PJ 102" X 24'...
