J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,952
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Althogh I have never seen the intinsification work, I do believe it will work.
If as you say that the rod end fluid from the FEL is routed to the PB port, then with the remotes in neutral the fluid would just flow through every valve in line and to tank. When you let the loader down, the fluid from the rod end would flow out the PB port , to the input of the remote, and if you operated the spool that the gage is plugged in, you could perhaps get pressure intensification's, as long as the lift cyl's were were descending.
If the only spool that you operate, is the one with the gage, do you get the 3200 psi? If so, it has to be pump generated, but where is the relief set and why is it not regulating/relieving the pressure.
However, when you lower the loader, you might not use high pressure on the base end of the lift cyl.
What would happen if you raised a 1000 lb load and shut the engine off, and then with the gage plugged in at the remote, and caused the lift cyl to descend and operated the remote valve at the same time.
Would the loader stop descending when you operated the remote spool?
If the flow from the lift cyl does exit out the PB port, then you should see the pressure caused by the load on the FEL, whatever it is and this pressure would be caused by the load and pressure on the rod side.
If it works like that, it would be the first valve that I know of that works that way.
According to the manual, it seems that 4Shorts 2250 psi is lower than the book psi for the remote. I believe it said something like 2600 ps ito 2700 psi.
