72 inch Rachet Rake on sale at TSC $199
   / 72 inch Rachet Rake on sale at TSC $199 #41
If the store you call does not have it in stock ask them to do a store search and they can tell you what stores have it in stock. Then call and ask them to hold it for you.
   / 72 inch Rachet Rake on sale at TSC $199 #42
Can anyone give me a rough guess on the weight of the 68"? Can I manhandle this thing into the back of my Expedition?
Thanks.
   / 72 inch Rachet Rake on sale at TSC $199 #43
   / 72 inch Rachet Rake on sale at TSC $199 #45
RailDog-loaded a 72" in my Durango Friday, the 66 should be no problem. Heavy for sure. Thanks Bdavis for the heads up on the 199.00 deal.
   / 72 inch Rachet Rake on sale at TSC $199 #46
Sorry-that should of been RailDawg & 68"
   / 72 inch Rachet Rake on sale at TSC $199 #47
This morning I bought the last one they had at the Bowling Green store. This thing is built like a tank. It is much heavier than the bucket where it attaches, I will have to be careful not to get into big rocks and tear up the bucket.
   / 72 inch Rachet Rake on sale at TSC $199 #48
FYI - I just called Fredericksburg, VA TSC and they did a store search and there are a good number of them still available here in VA.
In fact Charlottesville has 2! I just put my name on the one in Culpeper (I think that is the closest store) and he is holding it for me.
Now I just need to get off of work so I can go get it!
I hope this thing works for what I need it for!
Good Gravy!
Be well,
David
   / 72 inch Rachet Rake on sale at TSC $199 #49
I installed mine and worked it hard. Works great. The straps are not a problem and the rake did not move while popping out 15' youpons. I like the fact that it has 2 rakes at 90 degrees, it's useful pushing and pulling. It does a quicker, cleaner job than my tooth bar.
FYI: If your looking to put it on a smaller bucket the upper brackets that have the hook in it, the outer measurement is 60 1/2". The hook going through the hole will add an inch on each side =62 1/2" inside bucket.
Probably in the future I will add a bar to the sides to make it fit in the side holes where the tooth bar connects to make it bolt on/off.
   / 72 inch Rachet Rake on sale at TSC $199 #50
Thanks Bdavis for the heads up! Just grabbed mine this afternoon. If any one in the very most NW corner of Pa is interested there are still some available in Corry and Warren. Erie was out of the 72" and I grabbed the last one from Meadville. txdon you are right about putting it on a smaller bucket, I have a 62" which I was planning on adding tabs to use same bolt holes from the tooth bar. I stuck it on this evening and it does work, probably will still fab it so I can bolt it on though.
Can't wait till spring to use it now, shucks!
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
7' x 7' Steel Frame Cover Hut (A50121)
7' x 7' Steel...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
Caterpillar Engine (A50121)
Caterpillar Engine...
2022 Deere 317G (A50120)
2022 Deere 317G...
