What did you do to your tractor today?
   / What did you do to your tractor today? #81
   / What did you do to your tractor today? #82
Hello,
You can slide the sides off, and couple the wheels and cilinder off.
Then you can slide the boom uit of ik an couple a 3pt hich on.
Here you can see a picture of the bucket, i'ts factory made:
http://www.tractorbynet.com/forums/...ion-about-hydraulic-valves-2.html#post2659575
It Is a little bit other than this one:
Specs Hefbak
Wilco.
Ah, I thought these are different blades... You see - good conversion!:thumbsup:
Thank you for the links.
I also use 3ph bucket designed by myself. Now I'm constructing the new one (already the 3rd). It will be equipped with a hyd. cylinder.
   / What did you do to your tractor today? #83
Now do yóu have any pictures? :D
Wilco
   / What did you do to your tractor today? #84
Wilco
Yeah indeed. I'm just thinking Sutol soon will be angry if we use his thread not to the subject. :confused3:
   / What did you do to your tractor today? #85
I gave my redheaded mistress a Spa day! Bathed, waxed, checked all the fluid levels, new air and fuel filters and greased her up.
Long as its what you did to your tractor which it is:laughing:
I made a new overflow pipe for the radiator and fitted the shiney newly painted air filter with its 'new' stainless steel clamp then sat by the fire with a cup of tea and looked at it:)
Going to paint the back end of the tractor tomorrow and the backhoe before the weather gets cold again, its been 10c today but been too busy to find the paint tin:)
   / What did you do to your tractor today? #87
Unfortunately nothing for today ... That's why ... :(
   / What did you do to your tractor today? #88
Changed oil and filter today. Gave her a good bath yesterday, and she's been thanking me ever since.
   / What did you do to your tractor today? #89
I changed her oil, stoked her 3 times, rode her hard around the lot and told her that I would still respect her in the morning:shocked:
Went to spray part of the back actor and found that I was short on thinners so decided to use white spirit with the paint and wash out in the thinners I had left.
Made a good job too, managed to get more paint on as it wasn't as thin, the enamal paint drys slow so cant layer it on like the stuff for cars I find.
just the dipper and arm and the rams to paint tomorrow, get the fire on early:)
1989 John Deere 2755 (A53314)
1989 John Deere...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
Carnival Ticket Booth (A51691)
Carnival Ticket...
CASE 850M LGP CRAWLER DOZER (A52706)
CASE 850M LGP...
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
