Waxing your tractor !
   / Waxing your tractor ! #21
Mine gets a thorough spraying with Fluid Film each Spring and Fall and looks as good as new despite all the winter salt on the roads.
   / Waxing your tractor ! #22
Yes I wax mine. I also armor all the tires and rubber mat. Nothing like a spotless Deere!
   / Waxing your tractor ! #23
My dad has a 1970s era Kubota B7100 - actually he thought he got it in 1974, but tractordata says they weren't made until 1976. Either way, no one around had seen one at the time, and he got one of the first two that the dealer received. He has washed and waxed it at least once each year. That was all it took to keep it looking practically new. No one can believe how old it is today. I pointed out however that my 4005 has a lot more surface to wax than his Kubota and I can't say I look forward to it.
I actually find relaxing to be waxing any of my vehicles.
You should try, 303 protectant. Much better product than armor all.
   / Waxing your tractor ! #27
Waxing is part of maintenance. I use my tractor all year round for many chores and when it has wax on paint is much easier to keep tractor clean.
It is a tool but also an investment.
hay.. i use 303 also. it does seem to work nice
Been using it for over a decade on my motor home rubber roof, keeps it clean and protects it from the sun. Also works great on leather. Buy it online by te gallon it lasts me about 3 years. Good stuff !
   / Waxing your tractor ! #29
Jamming, good point. I do use 303 on my boat. It is awesome stuff!
   / Waxing your tractor ! #30
Just a comment about the tires and Armor All... There's a lot written on the web about the petroleum based tire treatments. Basically, they interfere with the additive put into the rubber to resist UV damage from sunlight. I recently looked at a 2-year old trailer that's been sitting idle mostly. The four tires on the axles had tire dressing applied often while the spare did not. The spare was in fine shape. The other four had checks and crack all through the sidewalls. Water based tired dressings do not create this problem. YMMV.
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2020 DRAGON ESP...
DEUTZ MARATHON...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
