my kubota rebuild
   / my kubota rebuild
Ugh, I keep forgetting to get pictures of mine but will post some. Simple design that should work on yours.
great!
really appreciate it
I'll remind you if you forget again...no problem.
I'm probably a few weeks out from that point anyways.
thx
   / my kubota rebuild #32
great!
thx
LOL, ok. For a taste of the setup go here for the parts manual. Page 3 has a breakdown of the frame. Parts 3 & 8 span from under the motor and back to the rear axle. You can see that it seperates in the middle so you can split the tractor without removing the frame. Part number 9 is a 3rd brace to the frame of the transmission if I remember correctly. So all you need to add is #8, #9 and weld the 1/4" steel on the right side (per the picture) of #3 to your existing loader frame. I wonder if these parts can still be bought.
http://www.kubotabooks.com/AutoInde...df&AutoIndex=9b30c761c67938e684a6623a034e1fde
   / my kubota rebuild #34
Hm, looking back I see the picture of another unit like yours has a 1640 loader. This is the breakdown for that one. http://www.kubotabooks.com/AutoInde...df&AutoIndex=9b30c761c67938e684a6623a034e1fde
The rear mount looks to be $45. I don't see the belly brace though, that one would be tougher to make.
Here is a video of the 4x4 version of the Kubota B1750 with the 1640 loader attached. Perhaps it will be helpful to see it in action. If you look closely, you can see the underframe shown in the parts diagram.
[ame=http://www.youtube.com/watch?v=jLsj7fw48DQ]Kubota B1750 HST 4x4 1419 HRS - YouTube[/ame]
   / my kubota rebuild
ok, I see how they are doing it. I think I can get a local shop to fab something up. I'll do some drawings and see what I can come up with for my bush hog loader
I might even be able to just buy most of those parts and then adapt to mine...as you said.
I'll post up pics and probably more questions soon
thx
   / my kubota rebuild
yeah, i can see some of the sub frame
I wish i could crawl under that tractor for a bit and get a closer look ;)
I'll post up some pics of what i plan to do and see what ya'll think
thx again
   / my kubota rebuild #37
thx again
This is from a different Kubota tractor but it clearly shows the subframe which doesn't look like it would be difficult to adapt and fabricate for your tractor.
ETA: See image in post below
Here is a TBN thread full of subframe pictures:
http://www.tractorbynet.com/forums/build-yourself/210977-custom-backhoe-subframe-kubota-l3710.html
And another thread from a different forum:
http://www.mytractorforum.com/showthread.php?t=198791
   / my kubota rebuild #38
   / my kubota rebuild #39
I was going to spread a little RTV onto the paper gaskets and install the oil seal with carrier, but found my old RTV tube had hardened up...so need to go get some in the morning
Just found your thread. This is one case where substituting RTV for
the paper gaskets is clearly superior. Paper gaskets are very fast to install
(as on the assembly line) but not as good as RTV. If you look at the
crankshaft where the seal lips rub, there was some wear, correct? If you
reinstall the seal holder with RTV instead of a paper gasket, the rubber
lip of the seal will rest on an unworn, larger diameter part of the crank.
That is due to the RTV seal being thinner than the paper gasket.
BTW, my B21's crank seal failed, which destroyed the clutch.
I don't know if you said...how many hours on this Kubota?
   / my kubota rebuild
so that looks like a subframe that supports both the fel and a bh.
now, I'm planning on getting a backhoe for this tractor (dont plan on plowing or mowing with it)...so I'm wondering if I should get the backhoe sooner than I had planned, so that I can tie them all into each other?
Hmmm, more investigation and looking around to do it seems :thumbsup:
thx for the picture!
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A52377)
2019 Chevrolet...
