what brand of oil filter on your vehicles
   / what brand of oil filter on your vehicles #51
I run Wix and Baldwin filters on what I have.
   / what brand of oil filter on your vehicles #52
Mann in my VW Diesels (15k mile changes using Mobil Turbo Diesel Truck oil) and OEM filters in my small engines using the same oil because I already have it on the shelf.
   / what brand of oil filter on your vehicles #53
Today, I cut up the used OEM oil filters for my autos. The Toyota filter was very well built and had a really nice looking supply of paper inside,with two metal end caps on the element..The Hyundai filter was heavier metal cased, also had a very nice looking element inside with metal caps and a metal relief valve. I did not see any plastic parts inside. I do believe that I can safely run these filters to their 7500 mile markers with no problems..
   / what brand of oil filter on your vehicles #54
I change the oil every 3000 miles and I buy the cheap name brand oil and filter that's on sale as a 5 qt/ filter package.
I'm not going to buy STP though. The last one I had was junk. The metal was so thin that the filter socket couldn't remove it. The metal would just deform. After exhausting every other attempt I finally hand to mangle it pretty badly and remove the exhaust manifold so I could get on the base.
I know I've read all about how a Fram has caused this and than and that they use paper and plastic valves in them but I've ran them for decades and never had an issue. I think it's luck of the draw and on occasion you get unlucky.
On the Kubota I have a kubota filter because I bought all the filters as a package (engine, hst, hydraulic, air, fuel).
   / what brand of oil filter on your vehicles #55
I remember seeing a Toyota filter cut away at the dealer years ago. The display said they had more surface area than the standard filter design. They look like nice filters and I think they reduced the size because of the more efficient design. It's too bad the dealer is too far away otherwise I might use them instead of the bargain ones.
   / what brand of oil filter on your vehicles #56
The pressure valve internal on a fram are junk, some cardboard ones are still around that had many failures, The filters that wal-mart sells are made by purolator filters and are the best bang for your buck, look it up on google. $1.97 filter that sells for $7.99 with a differnt logo. Short of buying Royal purple or Amsoil, the best oil for the money is Rotella T but you will mostly find it in 5w-40 but still has a higher shear rating than most. Rotella is the largest volume of oil sold in this country due to a large amount of trucking companys using it, full synthetic at wally world is $19.97 for a gallon. But i run Mobil 1, Amsoil, Rotella, Valvoline, Motorcraft 5W-20 in my motorhome. all great choices, one to avoid, because of high detergent is Pennzoil. Unless you change very often. Or you enjoy sludge.
   / what brand of oil filter on your vehicles #57
You sure about that or is your statement based on some one else's opinions?
I don't believe it has anything to do with 'detergent' in the oil but then please enlighten us, especially me. I'm all ears....:)
...and, I believe you should 'bone up' on oil properties because your nomenclature is in left field......
   / what brand of oil filter on your vehicles #58
From garden tractors , Ranger Pickup to International truck and Heavy Equipment. - Wix and Baldwin
   / what brand of oil filter on your vehicles #59
When you look inside, the design is very nice, sometimes they allow more paper filtering area.. I am not always at the Toyota dealer, so they sell three of them at a cut rate, sometimes a dollar cheaper each..I have been looking inside of oil and fuel filters for years. I took up the idea from seeing ads of Nascar engine filter full of rockerarm tips after their 500 mile races. I used to rebuild engines and always cut the first filter open after use for a Look-see??I am trying the Mobil-1 oil filters now as I am going with 5w30 synthetic oil to save my motors and some additional gasoline. By chance what are you calling Bargain filtering?
   / what brand of oil filter on your vehicles #60
Nothing but Donaldson
43017 (A51691)
43017 (A51691)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2000 Gallon Fuel Tank W/Pump (A50774)
2000 Gallon Fuel...
377669 (A51573)
377669 (A51573)
