MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,691
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
FYI, I bought one 2 years ago based upon MtnViewRanch posts.
RGM Manufacturing Road Boss Grader in Mandan ND is the parent mfr of the Road Boss.
They put me in touch with FHM Equipment in Mandan, ND, and Fred Myers (the owner) brought me a 7 foot with 24 inch sides (weight about 1100) to Idaho for 2850 including the delivery.
(FHM Welcome to FHM Equipment LLC rebrands the Road Boss with their logo per RGM).
One of the best units available IMO is a Road Boss, but they are big money. I believe that the RB units have the longest sides of all the units built today. Second would be GradeMaster, and they have 3 different levels. Not as long on the sides, but would probably be my second choice.
I would not go any wider than a 7 footer with your tractor and try to get a unit that is close to 1,000lbs at the minimum.![]()
Does the Grademaster look like a good heavy unit? It is make about 3 hours south of me. Is there a good need for the shanks like on the Cammond brand?
A picture is worth a thousand words about this second scenario, heres the pad I built for my new shop, the landplane along with a roller to pack produced this +-1/4" grade.
If a picture is worth a thousand words, my 80 or so pictures makes me quite a hefty sum, lol.
http://www.tractorbynet.com/forums/build-yourself/175396-dava-grader-process.html
Piston,
Mention was made of using crossmembers thicker than the standard 1/4". I don't really think the increased price of using non-standard steel is a viable option unless it is purchased or acquired at standard prices. My sides are 5/8" thick, which is overkill, but the steel was acquired thru a series of trades, basically costing me nothing. In fact, the only steel that I purchased was the grader blades from Dura-Grader for $5 a foot several years ago and $145 for the angle that they mount on, plus the bolts to mount the blades from Caterpiller(blades are Cat's) at roughly $20.
As far as serrated blades, in my opinon, they would not be as beneficial as just added weight. The drawbacks of them, MIGHT outweigh their benefits. My grader has a small opening between the end of the blade and the wall/side. That very small opening has a tendency to catch things and carry them that I really don't want staying with the blade, such as roots, rocks and other things, plus making paths or tracks in your road or yard that has to be covered by the second blade. Seems easy enough, but the rear blade doesn't allways cover what the front blade cuts.
David from jax
I talked to the guy at grademaster. It is 1400 for me to pick it up. One of my local tractor guys has the King Kutter line. The weight on their page said less than 500 pounds for the 7' model. The grademaster is around 1000 pounds. Will the King Kutter be too light to work good?
