log winches
   / log winches
Also, to all you guy's that responded, Thank You for the information. All good food for thought, which is why I joined. Nothing like an informed decision. I may make 1 less mess:)
   / log winches #12
Just to followup on hydraulic vs 3pt skidding winch options - it should be possible to plumb a hydraulic winch so that it could coexist with a front attachment such as a grapple (one also has to reduce the pressure and flow rate). The real problem appears to be that the line speed is a factor of 10 slower if one tries to adapt a truck winch like a MileMarker. Hence not very practical for pulling hundreds of logs off the slope. The Wallenstein skidders (for example) are not all that expensive and are designed for the purpose. But for me it will be another year before I need to go to work on forest cleanup.
   / log winches #13
I don't have any experience with a hydralic winch to know how fast the line speed is but i was thinking, If you already have one look around for an old 3 pt hitch slip scoop and mount the winch on top of the scoops frame. With a bit of scavanging and welding you could make a pretty fair skidding device and cheaper than a boughten one.
With your Aux Hydraulic already used you could add a Hydraulics Multiplier valve to add another function by just running a 12v wire and switch. I have 2 aux valves on my Kioti and going to locate a double multiplier to add more remotes. Just a thought .. . John
   / log winches #14
Thanks! I did not know about the Hydraulics Multiplier valve, that is just what I was looking for. My front Aux is already wired for a 12V switch so this would provide the switching capability needed (there is no need to run both the winch and a grapple at the same time). Also I found a different hydraulic winch (piercesales.com) which could probably run on my front hydraulics without having to adjust the flow or pressure (might want to swap in a faster hydraulic motor). So this option should be doable, mounting the winch directly on the loader arms, welding up a custom mount. The loader arms are way stronger than the frame of a truck so would be plenty strong enough for a front pull; the angles are such that loads on the lift cylinders would not exceed 20% of the pull or so. I have another year to decide how to handle this, but this option looks doable as well, while quite a bit cheaper than a PTO skidder and leaving the 3pt free for other attachments.
   / log winches
The Multiplier valve puts the hydraulic skidding back in the mix. And building this myself would save cost. I will post the build if that's the route I take.
Thanks again!
   / log winches #16
I emailed and then left a voicemail for Farmi and they never returned either. All I was asking was where the nearest dealer was. :confused:
   / log winches #17
Any thoughts about a 3pt/pto winch vs a front loader mount hydraulic winch? The Farmi etc. winches are pretty expensive for anyone not doing this commercially, and nearly impossible to find used. But given front hydraulics it would be possible to for example mount a hydraulic winch above a grapple (when closed) to be able to haul logs out and then pick them up for transport. A loader mount might have some advantages for winching logs due to the possibility of increased height as well as more convenient view/control. Safety is not a problem as one could easily put some mesh on front of the ROPS. Plus the 3pt is then available for other implements, such as a backhoe with thumb which is also handy for moving logs.
a guy once told me his dream set up for light logging/firewood would be a front mount winch with a 3ph grapple. use the winch up front to get the logs to the road, then turn around and just back up to it and grapple on and go. nice idea, but don't know how feasable it would be. i wouldn't want it on the loader frame, but if there was such a thing as a front 3ph with front pto.....? then that would be my set up.
as far as a hydrolic winch, don't know if they could be as fast or as powerful as a pto one, but you would have more fine tune control on the pull, especially when getting it close to the winch/tractor for skidding.
   / log winches #18
If your considering a hydraulic winch I have heard good things about the Ramsey RPH 8000 used as a logging winch with a tractor. It is rated at 2500 psi and 15 gpm for 8000 lb pull at 50 feet per minute. But will take more pressure I believe. (Better check though) I am not familiar with your tractors but it seems like for a lot of tractors you would not have to limit the flow or pressure. My tractor is 2500 psi and 7 gpm so I would get 8K pull at about half the rated line speed. Its about $1300 I think. Ramsey shows some hydraulic performance charts here:
| Ramsey Winch |
gg
   / log winches #19
This is the guy I have used for Farmi. He responds well, though it may take a couple days:
Jeff Smaby
3 Rivers Forestry
N9241 Perkins Rd
Mindoro, WI 54644
608-857-3357
(866) 638-7885
Sales@threeriversforestry.com
   / log winches #20
| Ramsey Winch |
gg
This sounds interesting - my tractor hydraulics are 16 gpm at 2900 psi so this might work. 50 ft/min is just about right. I will take a look. Another feature which would be useful would be the possibility to rig a wireless remote control so that one could just drag the cable up there and pull without having to walk back first.
I had a PM exchange about this where we discussed possible harm to the tractor from a winch. This is a definite possibility if not done right. I think it can be done but just want to pass on the caution about not overloading anything. It really depends upon the tractor and where you mount it (the loader on my TLB is integral with the frame hence stronger than usual). But one can also damage the 3pt with a winch so it is a tradeoff. Side loads should definitely be avoided in both cases (bear in mind this is from someone who hasn't actually put a winch on the tractor yet but I think this is clear).
1974 Ford F600 Grain Truck (A56438)
1974 Ford F600...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
