FEL Snow PLow size?
   / FEL Snow PLow size? #21
Well, that was quick! I found one for $250. but I think it's too much. Gonna offer the guy $200 and see if he takes it. Good luck on your project! Don't forget the pics. :)
Yeah it didn't take too long. There will be plenty of pics, but I'm not really going to start in on this project until the summer. No real time right now. About all I am going to do is take it apart and maybe get it over tot he sandblaster to clean it up and see what other problems are there that I can't see yet... But I might wait on that for a few weeks so it doesn't just rust over again...
I got some time to tear it apart today. Overall not too bad. A few bent pieces including a piece of the sector you can see in the pic below (the tab on the left is bent, compared with the one on the right and a weld is broken). A couple other small bends/dents to fix. Nothing that can't be fixed. Probably the worst finding was that the moldboard under the cutting edge was pretty rotted on one side. I may need to cut some of that out and stitch in a piece. Upper left in the photo - the black rusted areas. The pivot pins still moved, but had to be driven out of the sector. But they came out, so that's good. I will add grease fittings there.
I'm not sure if the cylinders can be re-used or not. The exposed chrome has a few pits in it, and it may tear up the seals. Dunno - that's an area I don't have much experience in. I haven't tried to move them yet. Ran out of time to mess with them.
New hardware needed all around too, of course. Gave the impact wrench a bit of a workout...
I got a rough quote of $200-300 for sandblasting which seems high to me. I may just rent a blaster and give it a try myself. Next step will probably be later this summer when I hope to get more time. I need some time to gather parts too.
   / FEL Snow PLow size? #24
The pitted chrome on the cylinder pistons will tear up the seals. Seals are cheap, it just takes time to replace them.
   / FEL Snow PLow size? #25
I got some time to tear it apart today. Overall not too bad. A few bent pieces including a piece of the sector you can see in the pic below (the tab on the left is bent, compared with the one on the right and a weld is broken). A couple other small bends/dents to fix. Nothing that can't be fixed. Probably the worst finding was that the moldboard under the cutting edge was pretty rotted on one side. I may need to cut some of that out and stitch in a piece. Upper left in the photo - the black rusted areas. The pivot pins still moved, but had to be driven out of the sector. But they came out, so that's good. .
Doesnt look too terrible for the money.
I did this to my truck plow as well.
Since I dont have a lathe, I didnt drill the pin. Instead, I drilled the plow itself as well as the sector. That way BOTH sides that the pin is in get greased. And mine didnt come out so easy. 10 minutes of pounding with a sledge:mad:
I Probably the worst finding was that the moldboard under the cutting edge was pretty rotted on one side. I may need to cut some of that out and stitch in a piece.
Yea, the meyers plows werent a great design for preventing rust. Another trouble area is usually quarter-sized holes that appear just above the cutting edge in 4 places......right where there is a back brace. Since it isnt welded solid...but the bottom 2 or so inches is, moisture gets in behind the angles and goes to town.
When I re-skinned mine, I welded it all solid to keep the moisture out from behind the back braces. And then a good paint before the accessories like the cutting edge and top flapper. And when I did pit them on, a little silicone to keep moisture from getting in behind.
Yea, it will wear out the seals and leak a little. If you are using your tractor hydraulics, I wouldnt worry about it. Because you could probabally run the plow for the tull 200 hrs til next service and it wouldnt leak enough to be a drop in the bucket. They arent under constant pressure.
But if it does get too bad, it is a PITA and about $20 each to do. Those gland nuts are on tight. If I ever do mine again, I will just buy new cylinder. baileynet.com has aftermarket replacement cylinders for like $50. For me, spending half a day and cursing like a sailor isnt worth trying to save $30 per cylinder. And since the rods are pitted, a new rod + seal kit would be even more than the whole cylinder.
Stainless would probabally be a worthwhile investment here.
200-300 doesnt sound bad at all if that is everything. The cost of renting a blaster + sand + a days worth of dirty and nasty work......
Go ahead and rent one if you want, but afterword I'll bet you think differently about 200-300 being high.
Good luck and keep us posted on your rebuild:thumbsup:
   / FEL Snow PLow size? #26
Dave it looks as if you found a really nice candidate for a tractor plow. I've done plenty of sand blasting and even made my own pressure blaster. It's one thing to rent a blaster but pease protect your lungs. I use a 3-M blower that supplies fresh air to my 3-M helmet. Yes it's expensive but how much are lungs going for these days?
If I only had one use for sand blasting I'd pay the money and get it done. It's very dangerous stuff and it's hard work my friend.
LD1 - thanks for the tips. Wasn't sure on what you meant by drilling the pin for a grease fitting?? I was aiming to do the sector and plow like you said.
I like your ideas on preventing rust. I will apply that here. Most of the mold board seems pretty solid, so I am thinking I may patch in that one corner and call it good. I'll know better once it is blasted.
I was thinking this might need grade 8 bolts to stand up to the abuse. Do you think SS will be strong enough? It is pretty soft by comparison... This is only going to see use on my driveway, so it isn't like I am commercial plowing either...FWIW
BTW, I thought it was ironic that I ended up with a Meyers ST90, just like you said a month ago in this very thread...
Ah the old Whitecap... Yes I know it. I'll let my secret out... I work for 3M developing respirators, and have for quite a number of years. So I have access to basically any safety equipment I would ever need. I appreciate the concern, but I am well aware of sandblasting hazards (and many other hazards you have probably never heard of...), so don't worry about that. I expect it is hard, but it is also something I have never done, which makes it worth trying out. A sand blaster here rents for $25/day (plus media), so that ain't bad at all, and it's not like I'm doing an entire forklift or anything crazy like that:laughing: Oh - and thanks for your business!
I guess my thoughts on the cost of blasting were #1 I'm a cheap SOB:), and #2, if I wanted to spend a fortune on the plow, I would have bought a nicer one in the first place (hmmm, pretty much the same as point #1...). So I'll probably give it a whirl myself and see how it goes. What is the recommendation for media? The Black Beauty stuff seems popular.
   / FEL Snow PLow size? #28
Glad to read your up on the hazards of this type of work. There are many who are not. I remember about ten years ago a friend of mine asked me to Sand blast a boat trailer for him. I told him I would and told him I'd do it just for the cost of the sand. Well he got mad with me and said he'd go a rent the equipment and do it himself which he did.
The thing that he didn't rent and couldn't rent was a good breathing apprentice but went on to do his trailer.
Before he managed to get it completed he ended up in hospital where he stayed for three weeks and he ended up loosing 40% of his lung capacity.
Now you see why I show concern about this sort of thing. I've done plenty of sand blasting and I hate it. The helmet and hoses are heavy and on days it's very hot not to mention back breaking but it's a nessassary evil to get the job done right.
I did all my collection for my musume with that 3-M gear. I purchased it new at an auction. I got the helmet, hoses and ambient pump for $250. and it was brand new at the time. I actually had to cut the boxes open to use it. I bought the full lot of them (6 lots in all) and sold the rest on fleebay and did pretty good out of it.
The black media is good stuff but clogs the blaster easily. It's more expensive (but safer) but you get less of it. It do cut good though.
The silica sand is easy to get around here but as you will know comes with many hazards but still does a great job.
Oh. I'm not a fan of stainless bolts on a plow application. They are soft, strip out easily and there are times you just can't remove them because they strip out.
Building the Brutal Blaster
Totally understood, Paul. Too many people don't get it when it comes to respiratory protection, and other safety equipment, and they end up injured as a result. As you note, some of those injuries can last a lifetime too.
I may give the silica sand a whirl. I need to see what I can find around here first.
You made out quite well on that system. They are pricey!
Question for you - You added a plate and a pair of rect tubes as reinforcement to the SSQA plate. What brought you to that point, and is it needed if you get a stiffer plate to start with?
   / FEL Snow PLow size? #30
The SSQA plate I used was made out of 1/4 steel. It was very strong. I did mine this way because I didn't want any surprises during the winter. I wanted to build it once and that was it. I had the extra meterial on hand so I added it plus it made it look neater in my opinion.
The only two items I changed was one, I added two skid shoes to the rear of the "A" frame. Doing that prevented the rear part of the frame from digging into the ground and the other mod was to add a trip shock to the blade to slow down the rebound of the blade after it tripped. That was a great addition to the unit.
I have a new cabbed 4240 coming in at the end of the month that belongs to a customer that's getting a similar set up as I have. Should be interesting :thumbsup:
Page with trip shock:
http://www.tractorbynet.com/forums/customization/131136-snow-plow-adapted-front-end-9.html
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
1271 (A50490)
1271 (A50490)
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2019 CATERPILLAR 299D2 XHP SKIDSTEER (A51242)
2019 CATERPILLAR...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
CATERPILLAR 336FL EXCAVATOR (A51242)
CATERPILLAR 336FL...
