Use Cut Off Saw for Cutting Bricks??
/ Use Cut Off Saw for Cutting Bricks?? #1
CHDinCT
Conn. & Florida
Kubota BX25, Z422-KW
OK, this might be a stupid question but I don't know the answer and need to know by tomorrow. So I have a 14" cut-off or chop saw for cutting metal. Bought it used and it came with a metal cut-off blade. Tomorrow, I need to cut down some brick pavers. Can I use the cut-off saw with the metal blade to cut the bricks or do I need a masonry blade to cut bricks? Hope somebody knows. Thanks in advance
/ Use Cut Off Saw for Cutting Bricks?? #2
You need a masonry blade in my opinion. The other problem is that the cut off saw really isn't designed to take the dust you are going to create. Masonry saws normally will run a water flow to cool and control dust.
MarkV
/ Use Cut Off Saw for Cutting Bricks?? #3
As far as I know, you need a masonry blade. I've cut many a brick and never used a cut off blade. It doesn't have to be a real expensive blade ($20 or so) and it will make a lot of dust.
I've done it with a circular saw and a right angle grinder. Make sure to wear a dust mask.
/ Use Cut Off Saw for Cutting Bricks?? #4
Ditto on the masonry blade. If they are real brick you can score them then they'll break at the score. I'd use the cutoff saw with the masonry blade, but I'd also not expect it to last long (with long being relative to a cleaner environment) with all the grit from the brick.
Also, angle grinders have masonry blades. You can use them for scoring or touchup.
/ Use Cut Off Saw for Cutting Bricks?? #5
Yup, you need that correct blade.
When I was a mason, when I still had a fifth lumbar disc, I cut a lot of bricks and blocks. I used garage sale circular saws and would get a year or so out of most of them before the brushes, bushings, and bearings went out.
/ Use Cut Off Saw for Cutting Bricks?? #6
I use my Milwakee 14 inch metal chop saw all the time for cutting pavers and cultured stone. I put a diamond masonary blade in it and it workds great. I like the blades with the cuts in them. I'm told they help with cooling. I've tried both and find the ones with the cuts just do a better job.
If it's a small job, I use my 7 1/4 circular saw.
As for dust, it might be an issue, but then how long do you think it will last anyway? I run my tools until the die, and then buy new ones. Better to get the job done and on to the next then not get it done or spend time looking for something else to do it when you already have something that will do it.
Eddie
/ Use Cut Off Saw for Cutting Bricks?? #7
I would get the proper blade, even a cheap one that looks like a metal blade but labeled for masonry, you won't need a diamond blade for a small job, and if you're just doing a small job I wouldn't worry about it hurting your chop saw. We had an old makita and used it for cutting everything for years before getting a proper brick saw, and it's still going strong. (although yes I agree the fine masonry dust doesn't do the motor any good) After you're done just take a blow gun and blow out around the commutator end (around the brushes) of the motor to clean it up when you're done.
OK, we have a consensus here - masonry blade it is. I do have a 4.5" grinder so I'll probably just try to get a masonry blade for that assuming it's cheaper than a 14" one. I only need to make about 12-15 cuts. Might try just scoring them good and then using a cold chisel to break them the rest of the way. Thanks again.
/ Use Cut Off Saw for Cutting Bricks?? #9
The dust will screw up your saw if you cut a number of bricks.Use the oldest or cheapest saw you have and go with the diamond blade.I cut a couple hundred pavers with my good circular saw now it has developed a slight wobble.It will be my new paver saw from now on.
/ Use Cut Off Saw for Cutting Bricks?? #10
Eddie
I bought a Harbor Freight saw 20 years ago, did the same thing with the diamond blade. Wore the blade out, saw is still going. Masonry fiber blades work too but don't last nearly as long.
/ Use Cut Off Saw for Cutting Bricks?? #11
That doesn't sound like many cuts, but I found the chop saw with a masonry blade a whole lot easier on me. I started with a circular saw, but after a couple of dozen cuts changed to the chop saw. I'll never use the smaller saw again. The standard 14" blades are pretty cheap.
/ Use Cut Off Saw for Cutting Bricks?? #12
Please don't forget to pick up a couple of respirators when you buy that blade. That dust is bad stuff.
Absolutely. I have one of those dust masks with the double carbon/particulate filters so I'll wear that.
If the 14" blades are cheap enough, I get one of those as I agree the chop saw would be much easier. Some of the cuts are lengthwise so the larger saw would be better.
/ Use Cut Off Saw for Cutting Bricks?? #14
Probably not advised as far as safety goes, but I put a 7 1/4" masonry blade on an angle grinder and use it for odd cuts. If you are only cutting a dozen bricks or so, it's not so bad. I think I bought 7 1/4" for about $20, not sure what 14" would cost.
/ Use Cut Off Saw for Cutting Bricks?? #15
I use a 7" diamond blade in a cheap 7" grinder, aim the guard so the dust doesn't get sucked into the motor. I have some 4" wheels too but use the big one more. I've used the masonry wheels before too but they are pretty poor.
/ Use Cut Off Saw for Cutting Bricks?? #16
Ive got a 4.5" diamond blade for my hand held grinder. I use that to make a score about a half inch deep and then a brick chisel to break it on the score.
its one handed, can be done at the location your putting bricks in (dont have to get up and or hand off to a second person) and you can always use the diamond blade to touch up the fractured edge if you need to.
Its quicker than cutting the entire brick with it (although it can be done) and is much less expensive than buying a 14" diamond blade
/ Use Cut Off Saw for Cutting Bricks?? #17
For long, or some angled cuts, I prefer to score the bricks with my 4 1/2 inch grinder instead of trying to fight the 14 inch blade in a chop saw. Once you have one brick get away from you while cutting it, you'll understand why I don't like cutting them that way. If you are doing anything round, the grinder works really good for that too.
Eddie
/ Use Cut Off Saw for Cutting Bricks?? #18
Eddie
Agree 100%. I only started using an angle grinder for masonry recently, but boy is it nice. More nimble, and less hassle than a saw. You can get real good at judging how to score and whack stuff with a little practice.
The grinder is especially handy with cinder blocks. I've used it both for extracting old blocks from a wall and for fitting new ones.
/ Use Cut Off Saw for Cutting Bricks?? #19
I use water with my junk circular saw and a masonry blade. Makes a big slurry mess but works fine and no dust. If I'm by myself I setup the garden hose to run on the brick, if someone's there they can do a little better regulating the flow.
/ Use Cut Off Saw for Cutting Bricks?? #20
Like the others said get a masonry blade. I have used them many times in my angle grinder and circular saw to cut them. Works great.
Chris
Adams Tilt Trailer (A61307)
Adams Tilt Trailer...
Dodge Charger (A56859)
2013 FORD F250 (A60460)
2013 FORD F250...
2020 DRAGON ESP...
XCMG CV83PD (A53317)
1994 Fontaine 45ft. 40 Ton T/A Flatbed Trailer (A59230)
1994 Fontaine...
