Buying Advice John Deere 3320 or 3520
   / John Deere 3320 or 3520 #21
Between the two choices presented, the cabbed machine would already be in my driveway;)
   / John Deere 3320 or 3520 #22
Very good feedback everyone. I felt good when I test drove the machine and I now I feel more optimistic about the durability of the 3520. The salesman is holding the machine until we meet again tomorrow. I will see if the dealer serviced the tractor and if there are service records available. If all goes well it just might be working my back 40 by the end of the week.
Thanks.
as far as service goes, i dont think it needed any real service yet. I have a brand new 3520 cab and it only needs a 50 hr engine oil change and the next service isnt due until 200 hours where you would have to change the trans fluid and axle fluid. Yours hasnt even hit 200 hours yet and there may not be any service records if the previous owner did the 50 hr oil change themselves
   / John Deere 3320 or 3520 #23
I have 3320 and 3720. Both have cabs and loaders. You can tell a difference with the turbo on the 3720. Once you have a small cab tractor you won't drive one without it. My open station Kubota just sits in the barn now. You will be surprised at how strong these little tractors are and how fast you can move around with hydro trans. My pick would be the 3520. More power and cab...easy choice.
   / John Deere 3320 or 3520 #24
I am deciding between a used JD3520 with cab, 300cx loader, and loaded tires with 182 hours or a new 3320 without cab and a 300x loader. I love the cab but the warranty is 3 months or 30 hours and the condition is used looking with a dented in front grill, scratch on the hood and rusted loader from being stored outside.
Welcome fellow newbe...that said, I own a JD3520 and can attest to the fact the cab is the way to go. That being said however, there are several things I would caution you on.
1st. be really careful on any uneven ground. I say this because the cab and wheel base is shorter and I have noticed a significant sence of being off balance a number of times (ok, my wife says the same thing). I know on my previous JD4310, the rear tires were filled and I did not get the same sensation in similar situations. (I did not get the back wheels filled on this 3520/ and do not know if this could be part of the answer. I do know the filled wheels did not aid me in negotiating wet pastures or loose sandy soils.
Everyone will have their own opinion and I would suggest taking the unit for several days and put it through the paces.
The turbo is great with the non-load setting and the exhaust is turned down so you do not have to worry about covering it up to prevent the turbo from running dry while going down the road...
Enjoy, just my 2C worth
   / John Deere 3320 or 3520 #25
All good points. I want to add though, i have a 72 in mmm on my 3520 cab and dont have loaded tires. I beleive the deck weighs several hundred pounds and with it being on the low center of gravity, i do not experience any of the top heavy feeling when i go on uneven terrain or slopes. Just some food for thought. MMM is a good addition if you plan on doing alot of mowing and are worried about mowing terrain and unstability.
   / John Deere 3320 or 3520 #26
I am real close to pulling the trigger on a 3520 with open station. I have over thought it enough. For me, I will be off and on the tractor a lot.
But if I was where you are and even thinking about plowing snow....cab all the way. 183 hours is nothing, even if they did no maintenance. Go for it...:thumbsup:
   / John Deere 3320 or 3520 #27
FYI- I have a 3720 with cab. If you are going to be on any sort of uneven terrain you will probably want to get wheel extensions.
   / John Deere 3320 or 3520 #28
Let us know how you make out! The cab looks great!:thumbsup:
   / John Deere 3320 or 3520 #29
Do you have a pic of your set up. How much wider does it make the wheels stick out?
Thanks.
Lots of good feedback. I am getting the JD 3520 with the cab with a tentative delivery date for tomorrow. We are getting snow today however.
The width of the rear wheels is just under 60" but I was told I could turn the rear wheels around to add a little more width. I was also told that I could unload the rear tires if necessary. I will try it out a while as it is before I decide on that.
Now I will move on to finding attachments. There is a Howse dealer not far from me. His prices for a new 60" rotary cutter are around what I am seeing on Craigslist for a used cutter.
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A57024)
Neckover GL24-2-7K...
Jack Daniels Wall Art (A55853)
Jack Daniels Wall...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
