Five gallon can, huh?
   / Five gallon can, huh? #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Today I went to fill a pair of those newfangled "safety spout" fuel cans with diesel. Although they are labeled as holding five gallons, you can only get a shade over 4 1/2 gallons in each one before the fluid will overflow out the filler hole. My older Chilton type cans that are labeled as five gallons will easily hold that much....been a long time since I have purchased a fuel can...what with all the downsized packaging for everything else we buy (like the 1.75 quart container of ice cream) I should have known better....:laughing:
   / Five gallon can, huh? #2
Getting to be same at some resturants,paying more getting tad less. :(
   / Five gallon can, huh? #3
maybe this is actually good news! the cans you got actually hold 5 gallons, but you have found a gas station that has pumps that register low, making you pay for less then you actually got, saving you money!
seriously though, maybe cans are contracted a little? need to get pushed out over time? sometimes my 5 gal cans will hold a little more or less depending on this. but 1/2 gallon is quite a bit though.
   / Five gallon can, huh? #4
Do the new and old cans look like they are the same size? If they look the same size then the customer should never notice the smaller can. That way we can save more material in making it and make more profit. Right?
Is it a can made in the good ol USA or an import?
Sort of makes you say " hmmmm" doesn't it?
Don't drink the cool-aid!
   / Five gallon can, huh? #5
I had that happen up in Ky at a Pilot. Pumped about 230 gallons and the pump registered 40. I told the manager, whiched saved them a fortune. I needed a shower but it takes 50 gallons to get a free shower. After having to pay for my shower out of my pocket, I told dispatch about the free fuel and they gave me my money back on the shower. Now when I have a choice, I remember when they could have helped me, and Ibuy my fuel at their competitor.(1000 gallons a week) . I don't forget...
David from jax
   / Five gallon can, huh? #6
Maybe a silly question, but did you let the fuel "settle"? It seems to me that diesel foams more when I fill my new can than it did in old ones. Mine will hold over 5 gallons but it starts to overflow at less than 4.5 due to the foaming. When it settles down, it fills on up to 5 gallons.
Yes, I had let the fuel settle, the can was made in USA, will post a picture of the two types tomorrow. Since it was brand new and never used, it should have had no deformation at all.
   / Five gallon can, huh? #8
Many companies are always looking for new ways to screw the consumer. Less is more... profit that is.
   / Five gallon can, huh? #9
If its a new can it may need some time with fuel in it to "pop" back into shape. I got 2 new cans myself recently and they held about the same as what you're saying on the first fill-up. On the second one they took the full 5 gallons and I noticed that after the first fill and sitting the sides bowed a bit, which was the difference. Try them again and you may find they hold the advertised amount!
You may be onto something there, these two new cans are shaped narrower and more upright unlike the older Chilton type that are like a square box...yet I am not sure if they will flex enough to hold another half gallon. You basically COULD get another half gallon IF you tipped it upright onto the rear corner and filled them, but the fuel would leak out once you set them flat. Hmmm...going to run out and take a picture now...BRB...the older red Chilton type holds a full five gallons while the new yellow can has an indicator line (marked black in the picture) that says "safe fill level" and it has 4.5 gallons in it at that mark. Yes it WILL hold 5 gallons of AIR.
   / Five gallon can, huh? #11
i have 2 of those cans. i can get over 5 gallons in them. You have to waight until all the fizz goes down or you wont get 5 gallons in them. It takes a little bit of time and patience. You have to adjust fuel flow so it trickles out of the nozzle and you will get over 5 gallons in them.
   / Five gallon can, huh? #12
Sorta makes you think if the pumps are calibrated correct doesn`t it? The containers I use, are labeled 5 gallons, but will hold almost 7 gallons according to the pump. I am temped to fill one with a gallon jug and see how many it will hold.
   / Five gallon can, huh? #13
AW Shucks JD quit your fussing. Enjoy the nice pretty color of that new can (plastic bottle), :laughing::laughing::laughing:
In this part of the world plastic cans don't last long. Sun eats them in a year or 2. I have a fair collection of metal cans. Not the little tin ones. Think I've bot 4 of the old style Lever open cap type a couple of 3 gallon round button style and 1 smaller (1 gallon??),
On the lever open I rarely put in over 4 gallons. Have never had a new 1, but bet it would leak sloshing around on my road.
If you have an Army Surplus store close, some of them have the Real Cans. Had a bunch of them at one time. All gone now. They may also have the metal button style can.
   / Five gallon can, huh? #14
I noticed you have one of those EPA compliant gas cans that takes forever to empty and you spill more than the old cans that had a vent. I bought a bunch of these at NAPA and drilled a hole on the opposite end from the spout, then used a string to work a tubeless tire valve up into the hole from the inside and hooked on a puller and pulled it in. Then you take out guts and you have a cheap ($1.00) vent that works fantastic, doesn't leak, and you can find a new cap real easy when you lose or misplace it. Try it, you'll like it...............
   / Five gallon can, huh? #15
Why fill it? With the new spout you can't get it out anyway
   / Five gallon can, huh? #16
Who uses the spout anyway. I thought everyone just takes the cap off and uses a funnel
   / Five gallon can, huh? #17
I got three new 5 gln deisel containers last year and now that the sides are bowed out they hold 5 at the safe fill line same as yours. Set it out in the sun tomorrow now that it is full and check your fill line (black pen) after the plastic softens.
   / Five gallon can, huh? #18
It looks like if you could fill it to the top with the handle full, it may hold 5 gallons, but because of the shape, you may have to fill it with the handle vertical to fit 5 gallons in, but that dosen't leave any room for expansion. I know that when I was in the Air Force, when they would fill the jets in the morning when the fuel was colder, it would warm up later in the day, and leak out all over the tarmac. That may be the case. Not sure. I use Scepter military cans that hold 5 galons, and you can drop them out of the back of your truck, and they will not leak a drop. They are expensive unless you can find them used. Scepter makes a pretty good can on the civilian market. They are made by our neighbors in the north. They must be made from old hockey pucks, because they are very thick. It seams to be much thicker plastic, and I have actually found them at Walmart. I have one that holds gas on one side, and bar oil on the other for my chain saws. Anyways, I really hate the new caps also. That why I have stuck with the military cans, you can fill a tank very quickly. They sell the civilian equivalent on Amazon for $23. Well worth the investment. I had to get a yellow cap strap, and label them, so my wife wouldn't use the diesel in the atv since both of the cans are green. This might seem funny, but I watched someone fill a HMMWV "humvee" in the military with regular gasoline, even though it said Diesel below the fuel cap. It reeked havoc, and was towed from the pumps.
Mitch
[ame]http://www.amazon.com/Scepter-Resistant-Closures-5-Gallon-Military/dp/B000MT94TC/ref=sr_1_1?ie=UTF8&qid=1335335537&sr=8-1[/ame]
   / Five gallon can, huh? #20
Don't let them fool you. The cans are getting smaller. I bought 4 cans over the last two years and they only hold 4.5 gallons now. The first few times I filled them I was also filling vehicle tanks at the same time and didnt notice. When I made a special trip it was plain. I felt much better about my fuel economy after that. I thought I had run through 100 gallons when I had actually only burned 90 gallons.
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
