65 Ford 2000 3 Cylinder
   / 65 Ford 2000 3 Cylinder #51
I have a 7' disk that made the front end light. I'd guess it to be around 800#, but the center of the weight is back a little ways from the hitch points. 110 lbs. of weight on the front really enhanced steering when the disk was lifted.
There was no problem using a 5' cutter, two botom plow, or grading blade. I know that my 6' Woods HB72 box blade weighed in at 635# and the 2000 handled it fine without the weights on.
   / 65 Ford 2000 3 Cylinder #52
Yes, I was referring to the belly drawbar.
He also had a spreader bar and that fit just fine.
Thanks for you input on the mowers. Yes, I am looking for a 6' finish mower.
What do you consider 'heavy' for a 2000 w/o any front weights, 500# ?
Tractordata says that a 3000 can pick up 1700 lbs 24" back from the 3 point.
Your 2000 should be rated about the same. It does not say if that is with front ballast though but I think it would have to be.
My Bush Hogï® weighs about 850 lbs and does make the front end a bit light if I'm cutting in hilly areas. Doesn't lift the front end but I can tell it's pretty light. It will heft my 7' finish mower around all day without making the front end light. Probably weighs around 600 lbs. A 6' would be lighter.
I do not run front ballast but am planning on adding some this summer.
Good to know. A 72" BB is on my list also.
If you're asking about the belly drawbar I am almost certain that they are different. I'm not saying it won't fit somehow, I just know the original drawbar was different.
That's a nice tractor you found there. You are fortunate find power steering on a 2000, that was an option.
My first tractor was a '72 2000 gasser. Ran it for a decade and still have fond memories of it.
I got over to try the swinging drawbar today, it fits but in looking at Messicks parts page I can not determine what the fastener is that is used to secure the drawbar. Looks like it could be a 5/8-11 x 2-1/4" G5 HH Bolt, no nut or washer called out. There are no threads to engage a bolt so it would seem it does not take a nut.
   / 65 Ford 2000 3 Cylinder #55
Push the clutch a few extra feet before you want to stop when you are bush hogging. .
if it's an 8spd or the rareish live 6spd.. it shouldn't be an issue...
   / 65 Ford 2000 3 Cylinder #56
on t he 8n with belly bracket there was a pin with nubs that went in to the bracket.. etc..
   / 65 Ford 2000 3 Cylinder #57
My Bush Hog鎬 weighs about 850 lbs and does make the front end a bit light if I'm cutting in hilly areas. Doesn't lift the front end but I can tell it's pretty light. It will heft my 7' finish mower around all day without making the front end light. Probably weighs around 600 lbs. A 6' would be lighter.
i know that HD servis 6' mower on the back of my 4600 made the front end light when i loade don my deckover trailer... ( think teeter totter! ) front wheel weights, loaded front tires, and 160# of weights up front solved that issue..
   / 65 Ford 2000 3 Cylinder #58
My swinging drawbar had a smooth pin with a retainer clip. The cilp slides onto the pin on the top side of the drawbar bracket.
My swinging drawbar had a smooth pin with a retainer clip. The clip slides onto the pin on the top side of the drawbar bracket.
OK, that's what I was thinking after looking at it. It was the only logical way it could work. Is the pin anything special or can I find it at my local TSC? The hole looks to be about 7/8", so I'm thinking a 3/4" pin.
Why can I not find the pin and retainer clip on the parts page? I see the drawbar and bracket and mounting hardware, but not the pin. Is it supplied with the swinging drawbar?
   / 65 Ford 2000 3 Cylinder #60
I was looking in an old toolbox yesterday and happened to notice there was a drawbar pin and the hairpin clip that goes with it in there.
This is what you want to hold the lower drawbar in a 3 cyl tractor.
These are available from the dealer for not a lot of money.
UNUSED FUTURE SB45 HYD SILENT BREAKER (A51248)
UNUSED FUTURE SB45...
48" Pallet Forks  (A52384)
48" Pallet Forks...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
UNUSED TOPCAT ECSSS7G200 HYD STUMP GRINDER (A51248)
UNUSED TOPCAT...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
