Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation
Wall #2 is up.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #112
Wall #2 is up.
Suggestion: Install the door header up tight under the plate, and just frame a 2x4 over the door. That way if you screw up it's easy to modify the height. Not so big a deal on a door, but if it were a 14' wide sliding patio door, you'd be kicking yourself. If you have the header there it's really tough to fix a wrong height. It also gives more solid support to the rafters, which is what you really care about anyway.
That's a good suggestion now that I already have the door framed.
Wall #3 is up. I put it up without the plywood on it so that it would have a little flexibility to fit between the existing walls. I also left out the window header. That wall was a breeze to stand up compared to the other two.
If I get time in the morning, I'll take better pics. For now I've earned a good night's sleep.
Wall #3 in better light.
I'm anticipating the next steps...
What's a good, cheap way to flash the windows?
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #116
This is as cheap as it gets ;)!!!
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #119
Ok, since I spoofed you on your flashing question, the least I can do is make things right and get you pointed in the right direction.
This website is a pretty good instructional on proper flashing techniques. I think after you review you will have a good idea what your situation needs based on the type of window you are installing.
Installing and Flashing Windows Correctly - Fine Homebuilding Article
Wow! 8 pages. It look like some good information.
After reading through most of the linked article (and other similar articles) what I need more information on is the sill pan. How do I make a sill pan, and what do I use?
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
LOT: (6) Pneumatic Tools, (3) Impact Wrenches, (2) Cut-Off Tools, (1) Grease Gun (A59076)
LOT: (6) Pneumatic...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1994 Club Car Electric Cart (A56859)
1994 Club Car...
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
