Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation
Wall #2 is up.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #112
Wall #2 is up.
Suggestion: Install the door header up tight under the plate, and just frame a 2x4 over the door. That way if you screw up it's easy to modify the height. Not so big a deal on a door, but if it were a 14' wide sliding patio door, you'd be kicking yourself. If you have the header there it's really tough to fix a wrong height. It also gives more solid support to the rafters, which is what you really care about anyway.
That's a good suggestion now that I already have the door framed.
Wall #3 is up. I put it up without the plywood on it so that it would have a little flexibility to fit between the existing walls. I also left out the window header. That wall was a breeze to stand up compared to the other two.
If I get time in the morning, I'll take better pics. For now I've earned a good night's sleep.
Wall #3 in better light.
I'm anticipating the next steps...
What's a good, cheap way to flash the windows?
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #116
This is as cheap as it gets ;)!!!
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #119
Ok, since I spoofed you on your flashing question, the least I can do is make things right and get you pointed in the right direction.
This website is a pretty good instructional on proper flashing techniques. I think after you review you will have a good idea what your situation needs based on the type of window you are installing.
Installing and Flashing Windows Correctly - Fine Homebuilding Article
Wow! 8 pages. It look like some good information.
After reading through most of the linked article (and other similar articles) what I need more information on is the sill pan. How do I make a sill pan, and what do I use?
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
More info coming soon! (A55851)
More info coming...
