Garage Dimensions?
   / Garage Dimensions? #11
Pettrix said:
I need the parking space (2 or 3 vehicles) and some storage and maybe a small workspace.
I might get a small tractor and park that in there also.
sounds like you will run out of space in no time flat. I have a four car garage and not even one car fits in it after my workshop was built and i moved my junk into it. I'm glad my tractor can't fit through the door, that would be all the less space I would have in there!
   / Garage Dimensions? #12
I would go with higher doors if you can. I have a 50x30 garage and the only thing i don't like is door height. You lose height from the doors and tracks as well so you want as much ad ylu can get.
   / Garage Dimensions? #13
I am designing my detached 4-car garage. What I have so far is it will be 46 feet wide by 27 feet long. Two garage doors @ 18 feet by 8 feet.
My question is in regards to door height. Will an 8 foot high door be adequate for a 4x4 truck? I am assuming a small tractor will need a taller down than 8 feet, correct?
are you going to heat and/or cool the entire garage? or just heat/cool shop area?
are you going to just put gravel for a floor? or pour a concrete slab?
are you looking at stick building? 2x4's, 2x6's, 2x8's, 2x10's, with siding and shingled roof like how a house might be built? or are you looking at a pole barn. with metal sheeting for sides and roof?
1000's of ways to do things, just trying to figure out some basics of what you want, besides questioning height. some ways of buildings, example pool barns, can be possibly cheaper to buy and have a higher height, and if not heating / cooling, can allow you to buy some "clear" plastic sheeting for easy "sun light" to come through in a few spots in the roof.
on other hand, you might be wanting everything to tie into the look of the house, for a "theme" and looks. and wanting to heat / cool and costs and construction can change. there are good amount of "metal shed companies" out there, some in state some out of state, that can come in and build an entire metal shed, with insulation, and heating. fairly quickly. vs say a stick building.
higher ceiling, = putting up lights higher for wide area lighting, vs placing a bunch of florescent bulbs ever so many feet, to try and light everything up.
Well, according to my architect, the garage will be 46' x 28' with 2 car entry doors. The floor will be concrete slab and the walls will be ICF/Concrete (as will the home walls). The roof will match the metal roof of the home.
The detached garage must match the theme of the home, per HOA rules.
   / Garage Dimensions? #15
Hit submit by accident.. Ignore
   / Garage Dimensions? #16
Pettrix said:
.The detached garage must match the theme of the home, per HOA rules.
Ouch! I don't think I could afford to build a cedar sided workshop to match my house.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
Trailmobile Van Trailer (A56436)
Trailmobile Van...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
