Welding Up a Cracked Rim
   / Welding Up a Cracked Rim #71
Has anybody here worked on 1700psi pressurized heat transport equipment containing 250C contaminated and tritiated coolant? Personal airlocks are another. Ever figure the tons force on the walls and doors with just 1/2 atmosphere of pressure?
All the inspections we do are on Nuclear reactors, and piping components. However we use pressurized water to test the system prior to going online.
The water removes much of the volatility when compared to air, but none the less, when the unit is online the systems carry radioactive steam up to 1800 PSI on a PWR vessel, and various chemicals used in the industry.
Air is much more volatile under pressure than water.
I must state we also use additional methods of inspection to check the full volume of the welds and/or repairs to ensure their integrity.
   / Welding Up a Cracked Rim #72
Ya, why spend money on a new one when you can be unsafe for a lot less money.
   / Welding Up a Cracked Rim #73
I had assumed that most people knew a tank of compressed gas is more dangerous than a vessel 100% full of liquid. The 100% liquid tank just makes a brief splash when it ruptures. The ruptured gas vessel or parts there of, can fly far and fast.
   / Welding Up a Cracked Rim #74
useless statement.. not even a valid argument. It predisposes the possibility of a safe / correct repair, thus the argument itself starts from a non valid point.
soundguy
   / Welding Up a Cracked Rim #76
Ok let me understand, this.. the little campbell Hausfeld air compressor in the basement I welded up 6 years ago is going to kill some fireman or policeman? Are you saying I need to chitcan the air compressor? Let's hear from some other people on here before I do that... And what the He77 does my love of money have to do with it? Your kinda pressing my buttons here, about the "blindly ignorant, and "love of money" things. You could have worded that a little kinder, don't you think?
James K0UA
KOua. Sorry but the Scrouge thing about the $$$ was not directed at you or any other person who doesn't put $$$ above a reasonable effort for safety. There are those out there however with zero regard for safety if it requires time, effort or $$$. Then there is also another group who has not heard tell that an ounce of prevention is worth more than a pound of cure.They will spend more time and money repairing an old fence and chasing cattle. Then it would cost to build a new fence.
   / Welding Up a Cracked Rim #77
gonna need a helmet to post on this thread. Weld the thingy allready.
   / Welding Up a Cracked Rim #78
I am going to appoint myself site moderator on this thread and all of you lunatics have to listen to me. I'm the only one that makes any sense on this here Internet. So listen up. This thread is officially jacked up. And rule 34 article 2 says that if any thread is declared jacked up, it is closed. So all you nut cases go outside and drive your tractors or pick tomatoes or whatever, but no more bullshitt on this thread. Go outside and play. It's not healthy doing what you're doing here. Someone is gonna blow an O ring. Ok? So it's over. That's enough. No more bullcrap scientific explanations about how to weld a oakies tractor rim. MMH, you're fired!
   / Welding Up a Cracked Rim #79
too many hand wringers.
probably has scared the OP to death by now.. :(
   / Welding Up a Cracked Rim #80
I am going to appoint myself site moderator on this thread and all of you lunatics have to listen to me. I'm the only one that makes any sense on this here Internet. So listen up. This thread is officially jacked up. And rule 34 article 2 says that if any thread is declared jacked up, it is closed. So all you nut cases go outside and drive your tractors or pick tomatoes or whatever, but no more xxxxxxxx on this thread. Go outside and play. It's not healthy doing what you're doing here. Someone is gonna blow an O ring. Ok? So it's over. That's enough. No more bullcrap scientific explanations about how to weld a oakies tractor rim. MMH, you're fired!
i like to sling poo like the rest here.. but do remember this is a family forum and we need to keep the language clean... there *could be* children reading here.. though they've probably died of broedom by now.. or are doing somehting safer than welding a rim like playing inthe street ...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A51572)
2016 Hino 195h...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
1267 (A50490)
1267 (A50490)
