Ford8n Antifreeze
   / Ford8n Antifreeze
well like i said the tires that are on it say 205-75-15
   / Ford8n Antifreeze #52
and see if they mention what WIDTH rim they are to be mounted on...
   / Ford8n Antifreeze
does a 8n have enough power to sit and idle run a pto generator to run things in the house?
   / Ford8n Antifreeze #54
Most times, the tractor would have to run at a high enough RPM to make 60HZ, and that is far above idle.
   / Ford8n Antifreeze #55
considering that a pto genset makes power the same way the big power companies do. you need the proper pto speed to spin the guts to make 60cps power. thus your pto needs to be turning at or around 540 rpm to make 60cps... thus your tractor will not be at idle, since pto rpm is a driect locked ratio based upon engine rpm.
yes, an 8n can run a pto gen of up to 12.5kw capacity, if the N is in good condition and governor works well.
   / Ford8n Antifreeze
while attempting to put new hydralic fluid it i was trien to tightin the drain plug the first one and i broke it clean off didn;t even attempt to pull that hard IT CAME OFF ALOT HARDER and it snaped it right in half anyone no were i can get one??????
   / Ford8n Antifreeze #57
Call ford? It may just be a threaded plug, look at tractor supply co? Or look anywhere on internet after dearching ford 8n parts.
   / Ford8n Antifreeze #58
I'm not sure what plug you are refering to.
an 8n doesn't have seperate sumps, thus there is no sump you should be putting hyd fluid in. the N has 3 drains. a pipe plug at the rear.. and 2 bung drains.
pipe plug type is a common hardware store plug... bung drains you can get salvage... *might be able to get them at a parts supplier*.. I havn't seent hem at tsc. .. their supply of N parts has dropped a bit..
   / Ford8n Antifreeze
ya the 3 drain plugs i broke the one underneath gear shifter wich the 2 are the same the only diffrent drain plug is dirrectly under the axel i orderd a new one and 2 new gaskets as well culdnlt find one around here and the tractor is not operational with out fluid in it bung plug is one im refering to
   / Ford8n Antifreeze #60
ps.. next time, you can make those gaskets out of gasket paper or non corrugated cardboard.
2012 Porsche Panamera Hatchback AWD Sedan (A50324)
2012 Porsche...
FAKE (A52472)
FAKE (A52472)
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
3pt Roller (A50121)
3pt Roller (A50121)
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
