Why the length of the top link pin is different?
   / Why the length of the top link pin is different? #11
If you purchased those implements new they should have come with the correct pins for that implement. Every attachment that I have bought new I made sure correct pins came with it whether it was a bush-hog,PHD or whatever. Now if you bought used thats a different storie.
I also on top center link depending on implement have used big thick bolts/washers in a bind. :2cents:
Boone
You must live a charmed life. My bush hog, woods box blade, or KK rototiller, KK rear blade never came with top pins. Either a pin thief was in the area, it was a cost cutting measure, or the dealer put them in the parts bin. I never expected them to come with attachment pins.
   / Why the length of the top link pin is different? #12
All of my Landpride attachments came with pins except rear scraper.
   / Why the length of the top link pin is different? #13
Buhler supplies top pins / links with their equipment?
   / Why the length of the top link pin is different? #14
I have several cat1 and cat2 implements. I don't think any of them have the same toplink width. Like mentioned above, every manufacturer is different. My IH implements have a very wide toplink attachment point. They will fit a cat3 toplink. I also have never had toplink pins as OE equipment. I do have a top pin for every attachment. Just makes it easier.
   / Why the length of the top link pin is different? #15
Sorry too hear that.
Boone
   / Why the length of the top link pin is different? #16
My Woods box blade came with a pin, middle buster, and bush hog (both from TSC) did not. Toplink width is different on all three.
   / Why the length of the top link pin is different? #17
Instead of one pin that stays with the top link, have a right-sized pin that stays with each implement.
Bruce
   / Why the length of the top link pin is different? #18
Just get a long pin and use it for everything. You're only ever going to have one implement on the tractor at a time. What do you need more than one pin per tractor for? (Except as a backup, in case you lose one, of course.)
My tractor came with a short top link pin. First implement I bought, it was too short to use. I bought a long one and have never looked back.
   / Why the length of the top link pin is different? #19
I bought one of each cat. 1 pin size that TSC carries. I'm covered. :thumbsup:
   / Why the length of the top link pin is different? #20
It looks like that implement is designed with a Quick-Hitch in mind. Either use the longer pin, or get a QH at forget about keeping different length pins altogether.
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2020 CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
2020 CATERPILLAR...
