Why the length of the top link pin is different?
   / Why the length of the top link pin is different? #11
If you purchased those implements new they should have come with the correct pins for that implement. Every attachment that I have bought new I made sure correct pins came with it whether it was a bush-hog,PHD or whatever. Now if you bought used thats a different storie.
I also on top center link depending on implement have used big thick bolts/washers in a bind. :2cents:
Boone
You must live a charmed life. My bush hog, woods box blade, or KK rototiller, KK rear blade never came with top pins. Either a pin thief was in the area, it was a cost cutting measure, or the dealer put them in the parts bin. I never expected them to come with attachment pins.
   / Why the length of the top link pin is different? #12
All of my Landpride attachments came with pins except rear scraper.
   / Why the length of the top link pin is different? #13
Buhler supplies top pins / links with their equipment?
   / Why the length of the top link pin is different? #14
I have several cat1 and cat2 implements. I don't think any of them have the same toplink width. Like mentioned above, every manufacturer is different. My IH implements have a very wide toplink attachment point. They will fit a cat3 toplink. I also have never had toplink pins as OE equipment. I do have a top pin for every attachment. Just makes it easier.
   / Why the length of the top link pin is different? #15
Sorry too hear that.
Boone
   / Why the length of the top link pin is different? #16
My Woods box blade came with a pin, middle buster, and bush hog (both from TSC) did not. Toplink width is different on all three.
   / Why the length of the top link pin is different? #17
Instead of one pin that stays with the top link, have a right-sized pin that stays with each implement.
Bruce
   / Why the length of the top link pin is different? #18
Just get a long pin and use it for everything. You're only ever going to have one implement on the tractor at a time. What do you need more than one pin per tractor for? (Except as a backup, in case you lose one, of course.)
My tractor came with a short top link pin. First implement I bought, it was too short to use. I bought a long one and have never looked back.
   / Why the length of the top link pin is different? #19
I bought one of each cat. 1 pin size that TSC carries. I'm covered. :thumbsup:
   / Why the length of the top link pin is different? #20
It looks like that implement is designed with a Quick-Hitch in mind. Either use the longer pin, or get a QH at forget about keeping different length pins altogether.
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
2020 Chevy Silverado (A56438)
2020 Chevy...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
VOLVO ECR25...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
