PTO generator
   / PTO generator
View attachment 272556I put this together just before the October New England storm. The tractor was run in high pto speed to cut down on the tractor rpm. When I built it I measured the circumference of the pulleys to calculate the needed diameters of the pulleys to get the correct 540 rpm to the generator speed of 1800 rpm. It is a 7kw onan generator. We did not use anywhere need full output and checked the voltage often. Once set the rpm/voltage was very constant. We ran it 16 hours a day for 7 days.
Great Job! If I could just snap my fingers and one would appear it would be alot like that. The only thing is I think I could get by with a much smaller generator.
   / PTO generator #12
Howdy,
The alternator portion of a generator come in a few different flavors.
Of course the main one here would be a single phase. There is of course 3 phase as well.
There are 2 pole alternators which need to spin at 3600rpm to make 60Hz 240volts current. That is why so many small engine which run in the 3600rpm range are direct connected to the alternator. (no gearing) Then you have a 4 pole alternator which spins at 1800rpm. (more expensive, considered heavy duty, commercial grade) Which is why so many generators which are diesel, have 4 pole alternators attached.
PTO generators = have gearing, smaller units known as residential spin internally at 3600rpm. So that 540rpm pto needs gearing to get it to 3600rpm. The larger pto generators have 4 pole alternators and spin at 1800rpm. They still have gearing to get that 540rpm pto to 1800.
The main thing to consider is this. Anything running at 3600rpm is going to make noise. Think about a car on the highway doing 60mph in second gear. Its redlined and sounds like it going to blow up. Imagine driving across country like that. Will that engine make it? That is why the slower spinning engine and alternator will last longer. They are also more expensive. The only quiet generator spinning at 3600rpm is probably the Multiquip Whisperwatt 7000. Small diesel running at 3600rpm and alternator head at 3600rpm.
A PTO operated implement can be run at different speeds. A PTO Generator needs to spin at the proper speed to make that 60Hz 240volts.
You can take a look at this you tube video which shows them putting load on a smaller PTO generator. It lugs down the engine pretty good.
Small tractor with 15KW pto generator which spins at 3600rpm. So you have the tractor noise and the generator noise.
   / PTO generator
btw, may need corrected, but it looks like pto generator manufacturers are recomending about 1Hp per 600 watts. (20HP for a 12KW generator)
   / PTO generator
As Ductape said sounds like your generators are designed to run connected directly to an engine. These will be difficult to adapt to a pto.
yeh that was a great point and it was something I would have never thought of. I have some roller bearings and mounts for pulley shafts if I needed them. If it required some type of true tolerances not easily acheived with that then one could actually just use a case from an identical engine. Even though I probably have cases for that I may not go that far cause it would probably look stupid.
I hate giving up and I haven't yet but I'm starting to wonder. That bigger one I have probably doesn't have the single bearing.
   / PTO generator #15
Another point I haven't seen made is your 31hp engine will not be making the 25ish hp required to 'fully' run a 12kw genny at under 1k rpm. I guess it depends on how light of a load you're looking at...
   / PTO generator #16
keep this in mind. running your tractor at a low rpm is running it OUTSIDE it's prime power band. that means you will have less hp.
also.. you will need to get the gear ratio correct to run the genny head to get correct output freq.
also.. fuel usage will DIRECTLY depend upon kilowatts of electricity being used ( load )
doesn't really matter what 'unloaded' fuel economy you are getting.. when loaded.. that will be the difference. nothing is free.. fuel has 'x' amount of energy.. and it will be less than perfectly converted to rotational, then electrical.. in a lossy process that will roughly consume 2pto hp per KW generated.
soundguy
I'm strongly considering building a pto generator setup for my belarus 250AS since that tractor (31HP) seems to get unbelievable hours per gallon, something like 5-10hrs per gallon (diesel) it seems.
I want to make my own from one of the 3 generators I have. I would like to be able to run the tractor at slow speed maybe less than 1000 rpm. I also have several gear reductions or "gear ups" maybe, whatever they are called. Don't know if I can use a reduction type backwards or not. I'm not sure what speed generators need to be or what the PTO speed is at lower RPM. It would be nice to get close the first time since it would take some effort to rig everything. Part of the reason I want to go to PTO is because I hate the speed and loudness of those portable generators. Also, they are expensive on fuel and are pretty unreliable. Any ideas out there?
   / PTO generator
someone tell me if this calculation is right. If you ran a 540 RPM PTO to run a 3600 rpm generator you would need about 7 to 1 and a 14" inch sprocket to a 2" sprocket. I say sprocket because it would probably need chain driven because 2 " would be too small for a pulley with a load like that. Seems like a cheap 3600 rpm generator might make the project ridiculous. If that calculation method was right then an 1800 rpm generator would be about 3.5 to 1 or 14" and 4" pulleys or 12" and 3". That doesn't seem right. If it is right then maybe 14 and 3 would be good so you could run the tractor slower? Is tractor rpm linear to PTO rpm? In other words if it's 540 at 2600 rpm would it be 270 at 1300?
   / PTO generator
Looking back at the one Dana Warner built it does look close to that. Maybe 12" to 2" ? Can't see the lower pulleys. He said his generator was 1800 rpm.
   / PTO generator #19
You have to count teeth if using a chain. For example, a 60 tooth sprocket would match up with an 9, which is a little tight and would probably wear the chain prematurely. A 12 tooth would be about the smallest, which would perfectly yield an 80 tooth. You need to find a ratio that is equal to 6.666667 between the smaller and larger sprocket for exactly 540 to 3600.
Here is a calculator. It's made for motorcycles. If you set the standard to 12 front, 12 rear, 3600 rpm and set the speed to anything, because it's not useful to your problem, then you can try different size sprockets in the new section to reduce to 540 rpm. Remember that you will be putting the large sprocket on the front or driving shaft.
http://users.tpg.com.au/jono794/tools.htm
   / PTO generator #20
and if belting.. figure slip too..
2006 Freightliner Auger Truck (A56436)
2006 Freightliner...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
2014 NISSAN NV CARGO VAN (A59575)
2014 NISSAN NV...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
16001 (A55853)
16001 (A55853)
