No oil in the water or vice versa sound guy. I did have some success running the tractor richer but something is still not right. Tractor just does not like this 4' foot brush hog. Finish mower is more to its liking.
Here is what I did tonight I ran the piss out of it stopping occasionally to increase the main jet mixture By turning ctrclockwise. Got it to rich and it started smoking as you would expect a engine to do that has more fuel than it can burn.
Gave up headed to the shop put the battery charger on and set idle to 400 ish rpm's and adjusted the idle circuit to the fo4 specs and directions, once I got that dialed in I tackled the main jet at full governed speed and end up finding there is at least a full turn and a half turn of the screw in between where it loses power and gains power plus rpm's. I set it in the middle of all that and left it.
Here is what is tough to put into words, when my tractor is running it seems to me that it always has a pop to the exhaust like it misses a beat everynow and then. The frequency of this miss or pop increases with rpm. I think it should run smoother than that but I have nothing to compare it to as in how it should sound when running on all 4.
I vaguely remember the sound our old farmall h made when running silage trailers back and forth from the harvest stores to the field, and to me the engine ran smooth as a sewing machine. This ford does not run smooth compared to it the farmall. Everything else we had was diesel and other than driving them sadly I am not that much of a mechanic.
If it cooler this weekend I am going to compression test the cylinders so I can better post here what kind of shape the old girl is in.
Very frustrated tonight.
