Buying Advice L, M, or MX series? Can you offer guidance?
   / L, M, or MX series? Can you offer guidance? #31
i have a kubota 7040su 4x4 fel gear tranny 2 rear remotes loaded rear tires cast centers i have put 33 hrs on it the tractor is to light at times i will tell you this dont go smaller then an m series tractor i had an L3800 it was a toy that belongs in the sand box i move 10 ton of stone it took 6 hrs to do it i moved them again with the 7040 in an hr my buckets only 6'' wider on the 7040 then the l3800 my i wish i would got a skid steer have fun tractor shopping
Caseman, it's posts like this that show your ignorance.
The L3800 is not a toy! It is a midsize tractor that does what it's designed to do.
Kubota makes smaller and larger tractors.
   / L, M, or MX series? Can you offer guidance? #32
Exactly, we have a BX, L and M, none "better" than the other, just different; all good tractors for their intended purpose.
Growing up on a 160 acre cattle and row crop farm, our main tractor was the same as all our neighbors, a 32 PTO HP.
   / L, M, or MX series? Can you offer guidance? #33
10 T of stone on 6 hours :eek: That dont speak too well to operator ability. You could do that with a shovel and wheelbarrow.
I get 20T loads dumped for my driveway. Take me all of an hour or hour and a half to spread it out 1 bucket load at a time. It takes 2-3 buckets to make a ton. So a 10 Ton would only have been 30 bucket fulls TOPPS. So I guess you consider yourself a good operator averaging 5 scoops per hour:confused2:
   / L, M, or MX series? Can you offer guidance? #34
I spread 80 tons of gravel earlier this year with the bobcat I had.
   / L, M, or MX series? Can you offer guidance? #35
Definatally no toy. It is quite a machine. But as mentioned, they make tractors of different sizes for different purposes. And ALL tractors will feel light at times when you push it to the limit. My 18k lb backhoe feels light at times when digging relly hard stuff or moving big rocks.
   / L, M, or MX series? Can you offer guidance? #36
if i was in your shoes it would be an easy choice with out thinking.id go with the MX5100 HST 4x4 w/fel.an itll do what you ask it todo.an it rides real good.
   / L, M, or MX series? Can you offer guidance? #37
hey don i had one they are toys
   / L, M, or MX series? Can you offer guidance? #38
hey ld1 i put 10s a thousands of hrs of tractors oper wat man maybe u and don ato come to my neck of the woods i ll show u wat i know
   / L, M, or MX series? Can you offer guidance? #39
I really wish I could understand that:confused3:
I dont care how many hours you have put on. If it takes you 6 hours to move 30 buckets of stone, then you are either doing something wrong, or you are moving it 2 miles away a bucket load at a time:laughing:
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
Volvo A40D Off Road Dump Truck (A56438)
Volvo A40D Off...
26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
26ft T/A Dovetail...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
