Moving firewood palette with BX, bolt on forks
   / Moving firewood palette with BX, bolt on forks #41
Chopped, do u have any pics of some of your creations? They sound cool.
   / Moving firewood palette with BX, bolt on forks #42
I hope u r still impressed when I clarify that the load of pavers was on the rear... ;)
I'll have to test out that pallet on the FEL and let u know the results. My forks weigh (I think) 350lbs. So...I'm thinkin' the pallet ain't comin off the ground with the FEL, based on the weight assumptions given a few posts ago. But... we will see... :D
Yup, I'm still impressed, I realized it was on the 3pt. Your Max 28XL is direct competition to my previous CK30 and I don't think my CK30 would have lifted that pallet on the 3pt, and wouldn't have even been close with the FEL, as I think you'll find with yours. There is no Mahindra dealer near by, so it wasn't even an option for me, but there's no denying, for the money, they make a big, strong, heavy tractor, much like Kioti IMHO.
That's heavier than my grand l's box blade, I need a better one for it.
You got to have weight to penetrate. Well at least in my crazy hard soil
   / Moving firewood palette with BX, bolt on forks #44
here are a few.nothing to pretty, but for the low cost of used lumber etc. they are works of art . Also not the old freezer as a tote, and the old oil barrel cut in half.:laughing:
Oh and the second ones show what happens when your to high with the forks onthe 'pallet 'type.
   / Moving firewood palette with BX, bolt on forks #45
The BX is a great machine. What I have is more like the B2920, I think. Mine is 28hp. Rear lift is 2200lbs. FEL lift is 1400lbs.
I'm not sure how much each paver weighs, but aside from a few broken ones, there are 208 pavers on the pallet. It would be cool to know what that weighs.
This is a link to the tractor I have:
Mahindra Max 28XL 4WD HST - Mahindra Tractors - Heavy Duty, Value Packed Tractors. Built Tough to Last with a 5 year Warranty
Will that pallet mover idea work for you at all? It costs the same as my forks...so, pretty reasonable, to me.
Thanks for comparing the Max to a B series.:thumbsup:
   / Moving firewood palette with BX, bolt on forks #46
Chopped, those r very creative. What tool did u choose to cut the oil tank with? How long did it take to cut? How difficult? Would u cut it again? I ask because I have two fuel oil tanks, which r in great condition, but if I don't find someone interested in them, I've been pondering ideas for cutting them into "rings" to hold the wood.
Thanks for the pics. :thumbsup:
   / Moving firewood palette with BX, bolt on forks #47
The OP pointed out that the mahindra site comparison actually measures it to the L3200. After he pointed that out, I had to recheck that for myself. :D It's a serious machine. Did u see the post above of the tree that tried to tangle with it? The tree didn't win :)
The Max 28 is larger (frame, tires) than the Max 22/25...and, I think, has the motor from the 3016.
But I think the Max 22/25 are also closer to the B series, than BX...not certain, though.
U r welcome. :)
   / Moving firewood palette with BX, bolt on forks #48
Sure Id do it again.One I used a torch, but it was messy .So ive progressed to using some abrasive wheels for the circular saw. they have them at wal mart for around 5 or so dollars for three.
I think I used one wheel if that.A note is if you do that, make sure you give the saw 'breaks'.It can heat up fairly fast. I used an older saw and it really takes a toll if you push them to much. Ive just lately been using a fan to blow cool air into the end of the saw.That helped greatly.With the chop blade you get a good clean cut.some suggestions are to not bury the blade any deeper than you need.I also went lightly to make the initial score mark and then I went back and forth working it.sometimes even cutting backwards.I drilled a few holes in the bottom for drainage.And then used a 4x4 for the skids. a couple of good lag bolts from the inside out the bottom into the wood.they are quite rugged.
   / Moving firewood palette with BX, bolt on forks #49
U r welcome. :)
I think the Max28 is close to a B3200 but I don't think I have seen one. I compared dimensions and weight on the spec sheet and they were comparable. The smaller Max 22 and 25 are like a B2320 and 2620 I think. I saw where you dug out that tree.:D
   / Moving firewood palette with BX, bolt on forks #50
Here is how I stack wood on pallets. I use cambuckle straps to secure the wood if I am moving any distance or over rough terrain. I have 14 pallets like. I think each one holds close to 1/2 a full size pick up load of wood. I did not want to build a frame on the pallets because they would take up a lot of space when I am not using them.
Here are the home made 3ph pallet mover I use. I also have a set of forks for the fel on the L4240.
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
