Snowblower electric chute rotator motor resource.
   / Snowblower electric chute rotator motor resource. #23
Amazing,how many ways the guys can come up with to do the same job.
This is how I did my electric rotator. (Next come the deflector.)
TGR
   / Snowblower electric chute rotator motor resource. #24
This is how I did my electric rotator. (Next comes the deflector.)
TGR
   / Snowblower electric chute rotator motor resource. #25
I am in the process of hooking up the power motor chute rotator and the power actuator for the chute deflector angle. I consider myself a pretty good back yard mechanic but I have a problem! :confused: I tried bench testing the motor and the actuator but can't get them to work. Each unit has two wire coming from them. I assumed the motor housing was the ground (-) and the the two wires from the motor were either up/down or right/left depending on which one I applied plus (+) voltage to. Maybe today I will try it right off the Kubota battery and see what happens. :mur:
   / Snowblower electric chute rotator motor resource. #26
chopped said:
This one is not to bad a setup it sure moves fast..
snowchute.MOV - YouTube
That ones mine. It was easy to put together and works great. Going on second year with no problems. I already have it set to go for this year.
   / Snowblower electric chute rotator motor resource. #27
Bugsrlb. Reverse the wires and see what happens, thats how it works.
   / Snowblower electric chute rotator motor resource. #28
You will need a DPDT switch or the aquvelent.
   / Snowblower electric chute rotator motor resource. #29
You mean put plus (+) to the motor housing and ground (-) to the wires???
   / Snowblower electric chute rotator motor resource. #30
I did buy the DPDT switches. Thanx
Hays LT1 Tender (A56438)
Hays LT1 Tender...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
Pickup Truck (A59230)
Kuhn Knight 8124 Slinger Manure Spreader (A59814)
Kuhn Knight 8124...
