Meteor 68" with no shear pin...
   / Meteor 68" with no shear pin... #1
Buckgnarly
West topsham VT
Kioti DS3510
Picked up a used 2010 68" Meteor, but there is no shear pin for the impeller. The auger has one, but the PTO shaft that came with it has no shear pin, and I do not beleive the guy had a slip clutch. Manual mentions the shear pin should be on the shaft, but not there. Anyone have any experience before I call MK Martin on Monday?
   / Meteor 68" with no shear pin... #2
On my mine there is a shear pin on the PTO shaft just before it goes into the gear box. There is also one on the shaft that powers the auger. Are you sure its not hidden by any shrouds.
Positive.....my old Meteor had the shear pin on the shaft, but this one uses two of the same ends, the ones that have the push pin release/lock button. I even took off the plastic cover to cut down the shaft, no shear pin. I'm wondering if the guy had a slip clutch, but I did not see it when I picked it up.
So i talked to MK Martin (third time I've contacted them, GREAT company to deal with) and it should have a shear pin end. Off to the local JD dealer to grap a new yoke tomorrow before the snow that might hit us Thursday.
2019 Deere 35G (A53317)
2019 Deere 35G...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2022 Horizon Trailer (A55973)
2022 Horizon...
