Picking a trailer for new JD 5083E
   / Picking a trailer for new JD 5083E #11
Looks like some pretty heavy loads on tandem single axles. This may or may not be the place to ask this question, but when evaluating load capacity of a trailer is it safe to take the total axle capacity and subtract the trailer weight to determine how much weight can be put on the trailer? For example, I have a 22' 12K bumper pull trailer that is 82" wide. I estimate the trailer to weigh 2000 lbs. So the max weight the trailer can carry would be 12,000 lbs axle rating(2 @ 6,000 lbs each) less the 2,000 lbs trailer equal 10, 000 lbs possible pay load. I realize tongue weight factors in, but it is difficult to calculate. Seem about right?
   / Picking a trailer for new JD 5083E #12
Yes, kind of. You really need to weigh it. Most 12k ttrailers are closer to 3k empty.
Chris
   / Picking a trailer for new JD 5083E #13
Chris
So if the trailer weighed 3k, the net capacity would be 9k? And the capacity could technically be increased by the amount of tongue weight too?
   / Picking a trailer for new JD 5083E #14
That is my understanding. My trailer weigh 4800 lbs empty and has a 7ton or 14k capacity. I figured 25% can be tongue weight, so 14k + 25% = 17.5k. If I then subtract the trailer weight of 4.8k, it means I can haul 12.7k on it.
I'm currently hauling lumber to the mill with it, and have had loads over 14k. Here's a 14.6k load:
So my gross weight going down the road was 27.6k, which is probably borderline for my truck. Fortunately, the mill is only 10 miles away.
I have also hauled a 6405 with this trailer.
And a boom lift:
Of all those loads, I would say the boom lift was probably the heaviest, and I hauled it about 50 miles on the interstate, crossing the Blue Ridge Mountains. Neither truck nor trailer every felt unstable or unsafe at any point.
   / Picking a trailer for new JD 5083E #15
And a boom lift:
Great pictures! I have a very similiar gooseneck just a different brand, mine scales out about 5100 lbs with chains, binders, and a couple 6x6 blocks. I dont think i could go back to a bumper pull trailer now. Here are a few pictures of some various loads.
Picking up my Ford 961
The Jeep loaded to go to camp
Delivering a buddies truck that he just bought
Twenty foot sea van, at this point it was almost unloaded, probably only 2-3,000 lbs left in it.
   / Picking a trailer for new JD 5083E #16
Chris
I have a 20' 7k trailer that scaled 2600 just on the axles, not sure what the tongue weight was, so yeah I would hope a 12k trailer would be more than 2,000 empty.
   / Picking a trailer for new JD 5083E #17
26,000 lbs and over should imply a CDL driver's license...
   / Picking a trailer for new JD 5083E #20
i haul my 7040sud fel loaded rear tires cast centers on my 10k 20 fot bumper pull trailer ii figure its 8-8.5k my trailers bout 1000ibs over
Hustler super Z zero turn (A56859)
Hustler super Z...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
2010 Ford F-150 Single Cab Pickup Truck (A55973)
2010 Ford F-150...
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
Harley Davidson (A56859)
Harley Davidson...
