Picking a trailer for new JD 5083E
   / Picking a trailer for new JD 5083E #11
Looks like some pretty heavy loads on tandem single axles. This may or may not be the place to ask this question, but when evaluating load capacity of a trailer is it safe to take the total axle capacity and subtract the trailer weight to determine how much weight can be put on the trailer? For example, I have a 22' 12K bumper pull trailer that is 82" wide. I estimate the trailer to weigh 2000 lbs. So the max weight the trailer can carry would be 12,000 lbs axle rating(2 @ 6,000 lbs each) less the 2,000 lbs trailer equal 10, 000 lbs possible pay load. I realize tongue weight factors in, but it is difficult to calculate. Seem about right?
   / Picking a trailer for new JD 5083E #12
Yes, kind of. You really need to weigh it. Most 12k ttrailers are closer to 3k empty.
Chris
   / Picking a trailer for new JD 5083E #13
Chris
So if the trailer weighed 3k, the net capacity would be 9k? And the capacity could technically be increased by the amount of tongue weight too?
   / Picking a trailer for new JD 5083E #14
That is my understanding. My trailer weigh 4800 lbs empty and has a 7ton or 14k capacity. I figured 25% can be tongue weight, so 14k + 25% = 17.5k. If I then subtract the trailer weight of 4.8k, it means I can haul 12.7k on it.
I'm currently hauling lumber to the mill with it, and have had loads over 14k. Here's a 14.6k load:
So my gross weight going down the road was 27.6k, which is probably borderline for my truck. Fortunately, the mill is only 10 miles away.
I have also hauled a 6405 with this trailer.
And a boom lift:
Of all those loads, I would say the boom lift was probably the heaviest, and I hauled it about 50 miles on the interstate, crossing the Blue Ridge Mountains. Neither truck nor trailer every felt unstable or unsafe at any point.
   / Picking a trailer for new JD 5083E #15
And a boom lift:
Great pictures! I have a very similiar gooseneck just a different brand, mine scales out about 5100 lbs with chains, binders, and a couple 6x6 blocks. I dont think i could go back to a bumper pull trailer now. Here are a few pictures of some various loads.
Picking up my Ford 961
The Jeep loaded to go to camp
Delivering a buddies truck that he just bought
Twenty foot sea van, at this point it was almost unloaded, probably only 2-3,000 lbs left in it.
   / Picking a trailer for new JD 5083E #16
Chris
I have a 20' 7k trailer that scaled 2600 just on the axles, not sure what the tongue weight was, so yeah I would hope a 12k trailer would be more than 2,000 empty.
   / Picking a trailer for new JD 5083E #17
26,000 lbs and over should imply a CDL driver's license...
   / Picking a trailer for new JD 5083E #20
i haul my 7040sud fel loaded rear tires cast centers on my 10k 20 fot bumper pull trailer ii figure its 8-8.5k my trailers bout 1000ibs over
500BBL WHEELED...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
HAY SPREADER (A58214)
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
