DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,580
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
A definite yes vote on the scraper. Although my old Overland isn't near what these newer one's with hydraulics are, it is the berries..!!
Let it be known, that cutting topsoil is much tougher than subsoil. It's much easier to keep an even cut in clay type materials. Front ballast is a must, whether it be a loader, or weights, with that type of hitch. Once you get "hooked in", traction should increase because of the down pressure being applied. My Overland is a 60" cut, but if it hooks into something pretty solid, or a rock, it will pull the front wheels of my Massey 180 off the ground.
In the perfect world, it would be sweet to have another tractor to put the box scraper on, and use the scarifiers to pre-rip what you are cutting. I have a subsoiler for my Super C Farmall, and I do my ripping with it. Makes loading so much easier.
The frost bits on that cutting edge should make it cut easier, it's a shame they don't offer a tooth bar cutting edge.
Also, a scraper can grade off your fill, and if it is a fill that needs compacted, you can load the scraper, and wheel roll the fill, if done in shallow lifts.
