What size plow
   / What size plow #41
So I've a few questions on plows -
Is the only downside to using a 1 bottom plow on the bigger tractor the time it takes to do the job?
How important are coulters?
What about gauge wheels?
What are the wheel spacings on your tractors. If they are significantly different the plows may not work to well.
Coulters are nice in trashy conditions or sod. They help reduce plugging from trash and help keep the forrow straighter in Sod.
Gauge wheels are almost a must if you don't have draft control.
   / What size plow
The problem I have finding a plow around here is that none have the culters or gauge wheels
   / What size plow #43
I'm pulling 3 16" and at 8" depth with my Mahindra 5530 4wd Turbo, AG1 tires, no ballast. The plow is a Ford/Dearborn 10-209 with coulters.
Paid $495 from a dealer.
idaho2
Now that my friends, is a great plow!!! What'd hafta give for that jewel???
   / What size plow #44
Paid $495 from a dealer. This spring I'll have pics in action. Plowed about 3 acres last year and everything shinned up nicely. Right now it's uncovered and I greased up everything that was shiney for the winter. I agree that I found a jewel.:thumbsup: For the OP do you have a float control on your Massey? I think he'll be able to pull 3x12 or 2x16 easily. If he can find a 3 bottom that he can unbolt the last unit, he should seriously consider that as an option. Can always put it back on if and when needed for a larger hp tractor in the future.
Idaho2
   / What size plow #45
Idaho2
One of the better pieces of advice so far. :)
   / What size plow #46
Idaho2
As a kid I learned on a 2 bottom behind an 8N. But soon graduated to your type plow behind and 861 Ford. I thought I was in heaven. So much faster than the ole 8N and 2 bottom. Thanks for sharing the picture, brings back lots of memories!!! :)
   / What size plow #47
I started on a 2n with the 2x14. That was 53yrs ago! Of all the dairy farm work, plowing was and still is my favorite farm job. Looked forward to it every fall..:thumbsup: I need to ask my brother, who has the farm now, what his favorite is.
idaho2
   / What size plow #48
You want to talk heaven..... My family plowed with a Deere 4020 powershift with a turbo and a 4 bottom Kverneland. So sweet. What I wouldn't give for that today!!
   / What size plow #49
Our neighbor was, and the next generation still is, a big farmer. He had the first 4020 I ever saw. I still distinctly remember hearing him doing field work. He had a fender mounted radio!!!!! You could hear that radio clear as a bell a mile away!!! I was sooooooo jealous!!! But then,,, that's why none of us can hear today.... :laughing:
   / What size plow #50
Not to stray too far off track, but...
I'm running a single bottom plow on my L3130 HST with 31 HP. It does fine in the sandy loam we have in most of the pasture, but there are areas it rises to the surface and just scratches the ground. The plow is very light - I'd estimate 100 lbs or so as I can literally pick it up myself. Is the weight of the plow a factor in the areas it skips to the surface? Would a heavier plow stay "grounded"?
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
Tradewinds Power Unit (A50120)
Tradewinds Power...
GREEN CLIMBER P23-80 REMOTE CONTROL SLOPE MOWER (A51406)
GREEN CLIMBER...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
