Heat Reclaimer for wood stove
/ Heat Reclaimer for wood stove #1
jerrybob
Super Member
USA
yanmar 186D....JD LT180....DR Brush Cutter
/ Heat Reclaimer for wood stove #2
I'd be a bit weary of cooling my smoke too much and leading to increased creosote production.
Same goes for wrapping the pipe in copper to generate hot water.
Maybe a post on Hearth could give you some more definite answers.
/ Heat Reclaimer for wood stove #3
cabin, source of heat is a 35 gallon drum turn on its side, it has 2 blowers/fans, one moves air around back side edge of the drum. the other, is a "reclaimer" i guess. it fits between the outlet pipe and the roof vent. it has a fan that blows air around the pipe. before it goes out the roof. it does put out some descent, to a point i do not want to put my hand or face in front of it.
no idea about creosote or like, but poor temperature gauge on the pipe, still goes up, and does not go down till coals are nearly out.
/ Heat Reclaimer for wood stove #6
I have used a Magic Heat type reclaimer on my old Cemi stove for many years without any problems with buildup in my chimney. Have good hot fires everyday with good dried hardwood..... They don't last forever, but I got 8 years out of my old one still in pretty good shape. Just repiped/put a new one in last summer and this is my current one in use as we speak... The biggest problem with them as the thermostats need to be replaced every three years or so...depending...
Thanks Jerry for the info........sounds like your happy with that model. Currently on sale at Northern Tools for $169. I have a shop with wood stove.....not well insulated....thinking a reclaimer would help on cold days. We don't get real cold.....30's mostly......once in awhile down in the 20's. Thanks for the comments.
/ Heat Reclaimer for wood stove #8
Part of the question would be the cost of the wood. If, like a lot of us, you don't spend any money on wood, there doesn't seem to be much of a point in the heat reclaimer.
/ Heat Reclaimer for wood stove #9
Looks like every time you blink those things go up in price. I think the first one I bought about twenty years ago was about $90, now... most places want $189... :)
Yea....I hear you. I have access to lots of wood so cost isn't the issue.....I was just wanting to warm the shop quicker....I thought the reclaimer might help?
/ Heat Reclaimer for wood stove #11
Be sure to get a ceiling fan or similar going to de-stratify the air when using a point source vs a forced air heating setup. 'Air-tight' stoves don't suck much cold air from floor level & heating the ceiling/roof won't warm the space, tho' snow will melt off pretty well.
Catalytic flue add-ons and built-ins were out there years ago, but I don't know if they stood the test of time or passed codes everywhere. They did promise to keep flue temp up & draft going well while minimizing creosote buildup. Are they still around?
/ Heat Reclaimer for wood stove #12
I see your point. Do you have a portable heater? If I want to get the edge off the cold in the pole barn while the wood stove is heating up, I just run my 75,000 btu torpedo heater for 15 to 30 minutes. Takes a dollar or two worth of diesel and then the wood stove keeps things warm. And it's handy to have around for other purposes.
/ Heat Reclaimer for wood stove #13
if you use I check your chimney more often as you will be cooling your exhaust more leading to creosote like they said. But if your letting that thing rip to warm the shop there probably is a lot of extra heat in that exhaust that you can reclaim.
Good idea.....might look into that...thanks.
Yea thanks for the comment. Haven't decided yet which way to go....but good advice on checking that chimney often....
/ Heat Reclaimer for wood stove #16
here is our heat reclaimer on the anthracite coal stove in basement. The brand is volgazang and cost 99.00, Ialso have one on my small wood stove in garage. They are thermostatic controled dont come on untill pipe gets to 350 degrees. So far they have done a goog job. Stove pipes are 6 in. 100_4440.jpg
/ Heat Reclaimer for wood stove #17
My parents had magic heat on their woodstove for nearly 30 years. They did away with it since it was too noisy and less cleaning of chimney needed. They have a tall concrete chimney so it cooled off fast. They bought one of those induction fans that is powered by heat and it sooooo much quieter.
here is our heat reclaimer on the anthracite coal stove in basement. The brand is volgazang and cost 99.00, Ialso have one on my small wood stove in garage. They are thermostatic controled dont come on untill pipe gets to 350 degrees. So far they have done a goog job. Stove pipes are 6 in.View attachment 301578
Thanks for the comments and picture....still checking my options.
/ Heat Reclaimer for wood stove #19
Vogelzang, got one of their stack thermostats on my stove... another great Michigan company.... down by Holland me thinks.....
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2006 Ford E-350 Enclosed Service Van (A59230)
2006 Ford E-350...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
Great Dane Van Trailer 1989 (A61306)
Great Dane Van...
UNUSED FUTURE FT50-(50) 12' PIECES OF GALVALUME (A60432)
UNUSED FUTURE...
