SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,346
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Watch a gauge while you run water slowly. That gives you pump ON/OFF pressure and an idea of makup time. Run water variously. Note if you can stall or reverse pressure rise. After that when you glance at the gauge you will see whether it is w/i pressure and whether rising/falling/static. Rising may or may not be during water usage. Static could be pump OFF no usage or pump ON at full capacity usage. Not likely to see it balance so close that you dont see a pressure creep. A bit of experimentation and you will be able to know a lot about the state of the system and know how to check it when in doubt by observing pressure while using water or not to get it to go on or to favor it going off.
