Amco Offset Disc
   / Amco Offset Disc #91
Nice work Brandi. I will suggest that you protect the valve stems on those tires. Large clumps of dirt coming off the disk gang like to rip off valve stems. Btdt
The tires she has on there would probably run without air. You would not believe how thick those sidewalls are and stiff...
Tom
   / Amco Offset Disc
Gotta go back to work tonight. I got up early this afternoon and pulled the disc outside. I wanted to see if it would hitch on front of the tractor. It does and that allows me to hook up hydraulics from my grapple diverter valve. This allows me to move the disc around while the BH is installed.
4-2-13 Disc Hooked Up to Tractor Front.jpg4-2-13 RED Disc & Booger Now What.jpg4-2-13 RED Disc Sees Daylight.jpg
I am going to buy a longer pin for hitching in front. Long enough to go through both upper and lower bracket on my tractor's hitch up front. With a longer pin, do Y'all think the front hitch mount is strong enough to push the disc up my dual tandem trailer ramps and dovetail to load? I mean, it is way easier to load connected this way. This way it moves like an aircraft being pushed with a tug.4-2-13 Disc Tractor Front Detail.jpg Oh yeah.......I noticed the other day my grill bottom, seen in the photo, has a huge dent in it. Must have happened running the grapple and a stray limb attacked it.
hugs, Brandi
   / Amco Offset Disc
Oh, I'm not feeling left out at all. While my lawn tractor might be GREEN, my tractor is ORANGE. Color doesn't matter much to me, I think most any tractor is pretty good! Maybe excepting the "VietNam rebuilds" and some of the Chinese.
Fred
Fred,
   / Amco Offset Disc
Fred
Fred,
:laughing:Your so right. Tractor color does not matter.
hugs, Brandi
   / Amco Offset Disc
Thanks BR,
I realized while painting the wheels that the stems are rubber. At least they should be steel. I'll either have to live with it, or take it somewhere they can remove the tire. I don't think tire shops want to put thick beaded aircraft tires on their mount machines. But I could ask. I would have to wait where I bought the tires, an hour after work for them to open, to have them do it.
I had one 3 inch pipe nipple welded to the rear rim of my old Ford 3055 (photo above) when I had a flat. Never got the chance to install the other rear valve stem nipple!
hugs, Brandi
   / Amco Offset Disc
That would be great using aircraft tires. Heavy duty and tuff. Hate to think of how many worn a/c tires i leaned against that were being used for the jetways....:D Nice paint job. I was midnite painter for 2 yrs in PIT. Then bid
Ld. Mech and got it for 3 yrs til I retired...
Tom
Thanks Tom. Where you with US Airways? I had a layover in PIT once. It was winter and raining. Real dreary looking. I'm more familiar with Phlliy's airport. While working TDY in ACY, (we were there flying casino junkets ) us mechanics made numerous trips to Philly to pick up parts shipments..........and replacement mechanics!
hugs, Brandi
   / Amco Offset Disc
Tom
I think this true. Especially with the duals. Funny thing..........the sidewalls do not have any max psi printed in them. They do say...............Not for flight. These are recaps.
hugs, Brandi
   / Amco Offset Disc #98
hugs, Brandi
Hi Brandi, Yes I retired from US Airways Jan 2012. Hired in with PSA in San Diego before our merger. Worked contract maint. with Top Gun on the F5's (MIG 28's in movie) previously.
Moved to PIT in '88. Worked and still in Pit area.
Keep them flying
Tom
   / Amco Offset Disc #99
Brandi, it's easy to see you've spared no detail and that disc is gonna 'fly'. Your professionalism shines through on the details of every job you do. Your dad would be bustin' with pride if he could see what you are doing. He's up in Heaven sayin', "That's my gal!" :thumbsup:
   / Amco Offset Disc
Oh wow Jim.:) You brought tears to my eyes.:cloud9: Thanks.:salute:
hugs, Brandi
54in Loader Fork Attachment (A55851)
54in Loader Fork...
Booster Cables (A55852)
Booster Cables...
(2) TRACTOR WHEEL WEIGHTS (A57192)
(2) TRACTOR WHEEL...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
PALLET OF BAR LOCKS (A57192)
PALLET OF BAR...
