LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #61
Here's what I use on my LS3010 (bought in 2010)
Type Wix Napa
Air 46449 6449
Fuel 33262 3262
Hydraulic 51365 1715
Oil 51365 1365
   / LS Tractor Oil, Gas, & Air Filter Information #62
Does anyone know what is required at 100 hours?
   / LS Tractor Oil, Gas, & Air Filter Information #63
Dwight.. PM sent..
   / LS Tractor Oil, Gas, & Air Filter Information #64
Thanks Boomer. Next question for the LS owners- What engine oil are you using and secondly where do you find your best deal on hydro fluid that meets the LS Specs?
   / LS Tractor Oil, Gas, & Air Filter Information #66
I use mystik 15-40 oil, and Mystik trans-hydraulic fluid in my G3033. Works great. My dealer uses Rotella motor oil and xtreme trans-hydraulic fluid from Oreilly's. Hope that helps.
   / LS Tractor Oil, Gas, & Air Filter Information #67
Changing the fuel filter this weekend. I have eyed it up and am a little confused. First I don't see a factory installed fuel shut off...am I missing it or is it not on there? If not how did you guys go about stopping the fuel flow? I guess the ol' screw in the hose trick should do it. Secondly there is what appears to be an overflow hose on the bottom. Does that just screw off...I guess I am looking for any tips from those of you who have done this already.
   / LS Tractor Oil, Gas, & Air Filter Information #69
Hey guys, I have a 2010 mccormick (LS industries) ct36 tractor it has an S4L2 mitsubishi engine. do any of you know which (if any) wix filters will work? Btw my filters are painted black so I cant get my filter numbers off of them. myy local dealer quit saleing mccormick and are no help. thanks
   / LS Tractor Oil, Gas, & Air Filter Information #70
Wixfilters dot com has LS tractors listed in their filter look-up utility. You can select tractor model or by engine. The S4L2 engine and filters is listed.
Bob
(3) 12/2 NM-B Copper Clad Aluminum (A57454)
(3) 12/2 NM-B...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A57453)
INOP/NON-RUNNING...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
