Property line on19.5 acres
   / Property line on19.5 acres #41
So now you know who REALLY does the work in the atorney's office.
I guess it's really not that surprising that they pay someone else peanuts to make them the big bucks!
I have always heard that you will never get rich working for someone else. You have to have someone working for you to get rich.
   / Property line on19.5 acres #43
Isn't it frustrating to look forward to this day, then have to wait a little longer? :(
Ah well, the day you start laying fence it'll all be behind you. :thumbsup:
You've gotten some very good suggestions here... as a forester I've used most of them to "connect the dots" when the line is scetchy. In your situation though 600 bucks is the deal of a lifetime, so long as he is going to mark it good enough for your purposes. The only reason he can do it for that price is because it's based on his previous work... (would you finish a motor job and put your name on it not knowing who torqued the rods down?) I would make sure that both you and the surveyor were on the same page about what he was going to do, and also be there when he does the work so that you can assist when possible and also ask questions.
This isn't the surveyor that did the division of the property for the estate settlement. This is a guy I have used on a couple of other properties that I needed surveyed.
I wouldn't use the surveyor that divided this property for anything. This property was originally about 80 acres & had about 2000 ft of county road frontage. When he was surveying he tried to force a right of way across my yard to this piece of property because the other 3 heirs wanted all of the road frontage & didn't want to give the 4th heir any of the road frontage.
   / Property line on19.5 acres #45
$600 for a fence line survey is a great deal. Most surveyors here will not get out of bed for less than $1000. My neighbor just paid $1400 for a fence survey along 1 side of a 10 acre plot.
OK, I'm sorry that I misunderstood. Yet I still stand behind my original statements; even more now, since I assume (shudder) that your surveyor is straightforward. I make my last comment on faith, because I hope that our professional organisations are weeding out the dufuses. (sp)
   / Property line on19.5 acres #46
Since the bush is thick and hilly, your only real option for a true location is to hire the surveyor. $ 600 seems like a deal. Make sure his price includes setting intervisible stakes. These can just be wood stakes. Without a survey you may get the fence on your neighbours property and if he challenges the location, you may have to get it surveyed anyway. Just make it a condition of sale that the seller pays for the survey or make an offer of $600 less than what you were going to pay. Do not rely on any GIS overlays. They can be off large amounts.
Al
I am a land surveyor and this statement is 100% correct. Don't go by the GIS, they are just a fancy picture and are rarely done to any kind of survey standards. Where I work, we charge around $100 or more for a two man survey crew, and just from what you described, $600 sounds cheap. Also, survey grade GPS doesn't work well in heavy tree cover.
   / Property line on19.5 acres #47
I use a GPS to hike all the time. Try this--
Get the coordinates at your two corners with a handheld GPS device. Open Google Earth on your computer. Start at one corner, mark it. Go to the other corner, mark it. Draw a straight line between the two. Now anywhere on that line, google earth with give you the coordinates. Put your mouse pointer on 4 or 5 spots along the straight line. Write down all your coordinates. Now go out and mark each one on the line untill you have enough points to be able to see your line all the way from corner to corner.
Not going to work and probably not going to even get close. First off the photos on google earth don't have any kind of ground control when they take the pictures, second, handheld GPS is going to get you within 10 feet at its best.
The plan is to have the surveyor lay out the line & put in t-posts about every 100 ft or so. Some can be farther apart where they are in the field but some will have to be closer because of the rolling hills & woods/thick brush.
   / Property line on19.5 acres #50
I am getting into the same but on about 5,00ft I have a survey from a company and neighbor is having his own done again today,the thing is,this fence has been there 30yrs and we are on him just alittle at the begining so going off just the pins and making a straight line isn't good at all cause you may not be straight,this is what my great grand dad and neight done 30yrs ago and this new owner of two years,we are having disagreements about now. I just spent 7grand on dozing it out. I have heard thou if its been there over 15yrs the old fence is the boundary,this true dodge man?
1604 (A57192)
1604 (A57192)
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
