Pole Barn Project
   / Pole Barn Project #31
A regular 8' ohd will not give 8' of clearance to the floor when open. They usually hang down in the opening by 3-4 inches. That can be remedied I suppose, but it would take careful installation measures and spring tension to get the full 8' of clearance.
Only if improperly installed would an overhead door hang down into the door opening. For a residential overhead door, the clear height will be 1" less than the door call out height, for a commercial door, it will be full height.
   / Pole Barn Project #32
Two observations....
If the roof insulation is typical reflective insulation with white vinyl one side, aluminum reflective face on the other side, it should be installed with the reflective side up.
Maybe it is just the angle of the photos, but it appears the bottom chord bracing is missing from the trusses.
   / Pole Barn Project
The bottom chord truss braces are there! The roof insulation is the more expensive version that has foil on both sides!! Double-Bubble-Insulation
   / Pole Barn Project #35
From what I can tell from the photos, looks like the crew did a great job on taping all of the seams on the insulation as well. Takes some skill to get them all tight and have the insulation lay nice and smooth.
Am sure you will get lots of enjoyment from your new building.
   / Pole Barn Project #37
Very nice. I really like the panels on top of the wall to let light in.
Eddie
   / Pole Barn Project
The floor has been poured. Now I just need the overhead door installed and then the rest is up to me. Up first is electrical, apron and finish grading.
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
2013 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2013 Ford F-450...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
Bush Hog PT 10' Mower (A50120)
Bush Hog PT 10'...
2018 Kubota L4701 (A50120)
2018 Kubota L4701...
