2013 dodge 3500 HD trailer towing uprated to 30,000lbs
Status
Not open for further replies.
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #111
In Tennessee:
You must have a CDL to operate:
Any single vehicle with a gross vehicle weight rating (GVWR) of 26,001 pounds or more. Any combination vehicle with a gross combination weight rating of 26,001 or more pounds, if the trailer(s) has a GVWR of 10,001 or more pounds.
So, you could have a truck with 26k GVWR and a 10K trailer to tow legally.
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #112
In Tennessee:
Thats not quite how its worded. You must have a CDL if: The TRUCK GVWR is over 26k OR if the TRUCK GVWR+the TRAILER GVWR (aka GCWR or gross combination weight rating) is over 26k AND the trailer GVWR is over 10k.
So a 15k truck and a 11k trailer is fine, as is a 16k truck with a 10k trailer, but a 16,001# truck with a 10,001# trailer is not,
Aaron Z
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #113
Yes, you would not need a CDL in America.
Period
A DOT number is required inter-state, and sometimes required intra-state.
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #114
Aaron Z
Annnnnnnd a 26k truck with a 10k trailer is fine.
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #115
You understand it!
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #116
Commercial Driver's License Program (CDL/CDLIS) - Federal Motor Carrier Safety Administration short.PNG
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #117
The Federal standard requires States to issue a CDL to drivers according to the following license classifications:
Class A -- Any combination of vehicles with a GCWR of 26,001 or more pounds provided the GVWR of the vehicle(s) being towed is in excess of 10,000 pounds.
Class B -- Any single vehicle with a GVWR of 26,001 or more pounds, or any such vehicle towing a vehicle not in excess of 10,000 pounds GVWR.
As Duffster pointed out a straight truck of exactly 26K towing a trailer of exactly 10K would not require a CDL
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #118
You'd have to be completely insane to tow that much with a light duty truck!! People seem to always overlook stopping safely.
That much weight being towed often, go medium duty.
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #119
I like your opinion and will disagree Sir. I along with many others in the US have made a living pulling loads with our trucks. Apparently you are not educated in the light duty truck market and what they can tow legally tow. I actually have current argument going, that if I am wrong on..will increase my $$
   / 2013 dodge 3500 HD trailer towing uprated to 30,000lbs #120
Apparently you have never priced a medium duty, as an FL can be had for slightly less money than a loaded Ram/Ford/GM!!
And not only that, but the medium duty will be working long after it is paid for, unlike the light duty truck.
They can tow more weight safely, are not maxed out on every tow like light duty trucks are, stop safer, and are a true heavy truck, not a light duty which is under built, but grossly over priced!!
A friend if mine hauled RV's, after a while, his 1 ton (not mentioning brand, no need for a war.) started costing him major dollars, made the profit margin slim, has looked at many medium duty trucks, seem to pencil out better over the ling haul.
Status
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
JCT SKID STEER QUICK ATTACH AUGER SET (A51243)
JCT SKID STEER...
NEW HOLLAND BR780 HAY BALER (A51243)
NEW HOLLAND BR780...
Case 721B (A47384)
Case 721B (A47384)
UNUSED FUTURE MINI SKID STEER HYD HAMMER (A51244)
UNUSED FUTURE MINI...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
