PTO shaft how do you keep it off the ground ?
   / PTO shaft how do you keep it off the ground ? #21
I had a chain that I sometimes used as the top link on the bush hog. When disconnected, I'd use the chain to hold the PTO shaft up. Just realized yesterday that I may have left the chain on the old bush hog.
On the chipper/shredder, I use a tension cord to hold the PTO shaft up.
   / PTO shaft how do you keep it off the ground ? #22
I wrap a waterproof plastic bag around the end of it and set it on the ground
   / PTO shaft how do you keep it off the ground ? #23
Any issues with condensate forming in the bag? That'd be my worry.
   / PTO shaft how do you keep it off the ground ? #24
Have a tractor for every implement? :)
   / PTO shaft how do you keep it off the ground ? #26
I just set mine down on a piece of 2X4 to keep it out of the dirt. Seems to work ok.
   / PTO shaft how do you keep it off the ground ? #27
   / PTO shaft how do you keep it off the ground ? #28
I use a left-over piece of swingset chain for the bushhog.
For the tiller, each half is maybe only 14" long. With them slid together, it cannot reach the ground but can come apart. So I pull the tractor half and lay it on top of the tiller.
   / PTO shaft how do you keep it off the ground ? #29
That, and water running down the shaft and through an imperfect seal between the shaft & bag, then being trapped in the bag.
Not an idea I'm going to adopt. I'm all about letting nature dry out the stuff it gets wet.
   / PTO shaft how do you keep it off the ground ? #30
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2019 TAKEUCHI TB290 EXCAVATOR (A51246)
2019 TAKEUCHI...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
43029 (A51691)
43029 (A51691)
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
