PTO shaft how do you keep it off the ground ?
   / PTO shaft how do you keep it off the ground ? #21
I had a chain that I sometimes used as the top link on the bush hog. When disconnected, I'd use the chain to hold the PTO shaft up. Just realized yesterday that I may have left the chain on the old bush hog.
On the chipper/shredder, I use a tension cord to hold the PTO shaft up.
   / PTO shaft how do you keep it off the ground ? #22
I wrap a waterproof plastic bag around the end of it and set it on the ground
   / PTO shaft how do you keep it off the ground ? #23
Any issues with condensate forming in the bag? That'd be my worry.
   / PTO shaft how do you keep it off the ground ? #24
Have a tractor for every implement? :)
   / PTO shaft how do you keep it off the ground ? #26
I just set mine down on a piece of 2X4 to keep it out of the dirt. Seems to work ok.
   / PTO shaft how do you keep it off the ground ? #27
   / PTO shaft how do you keep it off the ground ? #28
I use a left-over piece of swingset chain for the bushhog.
For the tiller, each half is maybe only 14" long. With them slid together, it cannot reach the ground but can come apart. So I pull the tractor half and lay it on top of the tiller.
   / PTO shaft how do you keep it off the ground ? #29
That, and water running down the shaft and through an imperfect seal between the shaft & bag, then being trapped in the bag.
Not an idea I'm going to adopt. I'm all about letting nature dry out the stuff it gets wet.
   / PTO shaft how do you keep it off the ground ? #30
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2023 UNVERFERTH 632 LOT IDENTIFIER 166 (A53084)
2023 UNVERFERTH...
2024 JOHN DEERE 8R 280 LOT IDENTIFIER 7 (A53084)
2024 JOHN DEERE 8R...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
