BGigHarbor
Gold Member
Well, some people use it when raking their fields. The rake follows the ground instead of the tractor. I use it when finish grading-smoothing my roads, especially at intersections where the camber of the road changes as you go around the corners. That way the implement follows the ground instead of the tractor. See a trend? You use it when you want the implement to follow the ground, not the tractor.
If I were you, I would be on the phone and getting 2 of those remotes with the float function.![]()
Since it seems like no disadvantage to the float (except price) I put in a call to the dealer to ask if I can switch to 2 floats instead of 1 (so 2 floats and one double action). Naturally it's a couple more bucks, but the only reason I didn't order it that way originally is I didn't know when I'd need two floats.
Better to have the flexibility I guess as I am sure I'll find all kinds of ways to use the rears.
