Buying Advice Mahindra 4035 HST vs. Kubota L4240 HST
   / Mahindra 4035 HST vs. Kubota L4240 HST #71
Its what Kioti specifies! Are you saying you know more about their Tractors than them?
Not at all, I guess the better wording for a bunch of nit-pickers would have been "Since that's what they specify, the geometry of your tractor coupled with it's capabilities and ratings and so on must be plenty to prevent overloading your front axle when working with your loader at capacity." But then again those same nit-pickers would have picked up on the point that I had previously said "I'm just saying that with a loader capacity over 2500# on my tractor, I'd have more than 1000# on the back if using the loader to capacity, especially if the front tires are flexing the sidewalls a lot (I think of that flex as a visible indicator of when to add more ballast to the 3 point since it directly translates into the pressures the axle and steering are under)."
   / Mahindra 4035 HST vs. Kubota L4240 HST #72
Ags flex cause they are taller and thinner. And I have NEVER picked nit in my life.
   / Mahindra 4035 HST vs. Kubota L4240 HST #73
OK. And would you say by watching the amount they are flexing is a good way to gauge how much pressure the entire front axle is under? And if so, and you 'gauge' that it is more pressure than you are comfortable with, the solutions are to work less or add more weight to the 3 point? (obviously not to the point of overloading the 3 point though)
Couldn't prove it much by me :D
   / Mahindra 4035 HST vs. Kubota L4240 HST #74
Need to use your Ag tire flex gauge.I have R4 tires so I don't have to worry about that. Now your being trollish.
   / Mahindra 4035 HST vs. Kubota L4240 HST #75
How about going with a 10 ply front ag tire verses the standard 6ply ag front tire?Think that would reduce flex?Do some research on that one?
   / Mahindra 4035 HST vs. Kubota L4240 HST #76
Why do you want to debate more obvious things? So you can try to blame me for starting that debate as well?
   / Mahindra 4035 HST vs. Kubota L4240 HST #77
Just stating the FACTS.Not blaming you for anything.You seem to like research so here you go.Good luck.
   / Mahindra 4035 HST vs. Kubota L4240 HST #78
Sorry, I just find it irritating to hold a conversation in a discussion board and people mistake what is said and then begin to twist things.
I just made a couple points that sorta progressed into a decent discussion and then with a new arrival or two to the conversation it spiraled into nit-picking and name-calling.
   / Mahindra 4035 HST vs. Kubota L4240 HST #79
Sorry, I just find it irritating to hold a conversation in a discussion board and people mistake what is said and then begin to twist things. I just made a couple points that sorta turned into a discussion and then with a new arrival or two to the conversation it spiraled into name-calling.
I have not twisted anything nor have I called anyone any names. You did.
   / Mahindra 4035 HST vs. Kubota L4240 HST #80
Maybe you need to go back to POST#59 &#69 you called me a TROLL.Does that ring a bell?BO-HOO !
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
CATERPILLAR D4G LGP CRAWLER DOZER (A52707)
CATERPILLAR D4G...
2022 Chevrolet Tahoe FL SUV (A55853)
2022 Chevrolet...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
