Buying Advice Mahindra 4035 HST vs. Kubota L4240 HST
   / Mahindra 4035 HST vs. Kubota L4240 HST #81
I have not twisted anything nor have I called anyone any names. You did.
You mistakenly thought that I said "once a week" and jumped on me demanding I prove something when you didn't read it right in the first place. Then when I clarified that my point was only that front axle failures are a concern on CUTs you dismissed it cause the thread that had popped up the other day was two years old; like reality changed in two years and there's no way such a thing has happened since or could happen anymore.
Maybe you need to go back to POST#59 E you called me a TROLL.Does that ring a bell?BO-HOO !
This was after you started into an argument about a simple point I made, then tried twisting it back on me like I started an argument about it and began the "weekend farmer" and "oh great one" stuff. So go ring your own bell, ya got a short memory...
Troll isn't so much a name, as it is an adverb describing a particular behavior that's been displayed throughout the latter half this thread. Honestly, it's up to future readers to decide, so bad call on my part...
   / Mahindra 4035 HST vs. Kubota L4240 HST #82
Anything specific about Mahindra makes you think they aren't expert enough to design efficient tractors?
Not other than it seems like a tractor can meet my requirements with less iron. I run out of PTO power well before ever losing traction. I have mostly flat ground so weight does not benefit me. Some people think weight is good and I think weight is good for some people but not all. Sounds like Mahindra is a solution for you, so good job choosing it. I like my JD, MF, Kub and Case.
   / Mahindra 4035 HST vs. Kubota L4240 HST #83
Did you even read those? Its the Wheel not a front axle that broke.
   / Mahindra 4035 HST vs. Kubota L4240 HST #84
You will do well here.I can see that now.Good luck,I wish this website had a IGNORE user button.
   / Mahindra 4035 HST vs. Kubota L4240 HST #85
And it keeps coming back! Worse than the energizer bunny
   / Mahindra 4035 HST vs. Kubota L4240 HST #86
   / Mahindra 4035 HST vs. Kubota L4240 HST #87
The wheel came off due to a broken axle shaft, yes, I did read it. It said the shaft had even been made hollow at the point in which it had broken. It also had said the new part had been redesigned. I read every post all the way through. I hate seeing broken stuff and always like to know how best to try and avoid it.
Good test (I guess) if you read it too, bad bluff if not...
   / Mahindra 4035 HST vs. Kubota L4240 HST #88
Good test (I guess) if you read it, bad bluff if not...
The reason was bad welds. They even machined thru a few.
   / Mahindra 4035 HST vs. Kubota L4240 HST #89
By the way, good job hijacking OPs thread. As far as I know neither of ya have either of the tractors in question. So what's your horse in this race if it's not to simply be a disturbance?
Notwithstanding the unnecessary wrangling on the part of some, I am grateful for the additional info. on the subject. Any other advantages and disadvantages of the models will be appreciated.
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2018 Ford F-550 4x4 Stellar EC3200 Crane Service Truck (A55852)
2018 Ford F-550...
Gulf Antique Fuel Pump Art (A55853)
Gulf Antique Fuel...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A57024)
PENDING SELLER...
