wr long or ??? for brush & logs?
   / wr long or ??? for brush & logs? #81
This summer I chose to fit a grapple on the minidigger to keep the tractor free for other tasks.
Nice work. You fab that yourself?
   / wr long or ??? for brush & logs? #82
Well the bottom line is they make different grapple designs, because each design works best for certain jobs.. I don't think there is a "best" grapple design for every thing, each design is best at some things, and maybe a compromise at other things..
James K0UA
Thank you, James, for your succinct summary.
How is the cat?
   / wr long or ??? for brush & logs? #83
How is the cat?
The kitty is fine! And says HI!:)
James K0UA
Have both the blade and the grapple here. Like the blade. Not sure about the grapple, had a bad experience, it arrived with all the fittings finger tight so it spewed fluid all over the place.
The grapple just got here, not sure if I like it or not. A neighbor who knows way more than me said I won't like it because it won't hold one tree.
I'm stewing on how to grab stuff. Stay tuned.
   / wr long or ??? for brush & logs? #85
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=341637"/>
James K0UA
Cool cat
   / wr long or ??? for brush & logs? #87
Mine holds one tree.
And a different one tree.
If you need to hold one itty bitty skinny tree, to cut with a chain saw, keep one or two short fat logs handy to fill up the space in the grapple or just clamp it with the tips of the lids.
   / wr long or ??? for brush & logs? #88
You may be able to put the tree in the grapple diagonally so one lid can clamp down on it.
   / wr long or ??? for brush & logs? #89
Took a look at your new grapple from ETA, looks good (maybe your neighbor is a little jealous!?...) What did he mean (it won't pick up one tree?
I'm guessing he is saying that the grapples opening is to big, like the one I have (opens to 49 inches- and while it is true that many logs are not tightly gripped in the grasp of the grapple- it isn't like there going to fall out.
but then sometimes you get a piece that is so large it will barely fit in the jaw, that has been my experience.
Got a little bummed that my grapple wouldn't hold some smaller logs tight -then ended up with some that were so large I could hardly fit them in . This tells me I got the size i must have needed!!!
and I think you did to.. my 2 cents
   / wr long or ??? for brush & logs? #90
What do you mean it won't hold one tree? The nice thing about the open bottom grapple is that you don't need to rely on the clamping force to hold the tree in, but rather the weight of the tree just sitting on bottom of the grapple.
I can say I have never had trouble holding a tree that was too small, now, too big has happened but never too small. My only issue is that I can't lift 3k lb logs but that has nothing to do with the grapple.
12 in Large Excavator Bucket (A52377)
12 in Large...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2000 Toyota Tacoma Pickup Truck, VIN # 5TEWN72N6YZ690085 (A51572)
2000 Toyota Tacoma...
Year: 2005 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2005 Make...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
1991 Mack RW713 Day Cab Truck, VIN # 1M1AY10Y4MM005693 (A51572)
1991 Mack RW713...
